Saltar al contenido principal
iRulu AX760 Motherboard Replacement
Qué necesitas
  1. iRulu AX760 Motherboard Replacement, Battery: paso 1, imagen 1 de 3 iRulu AX760 Motherboard Replacement, Battery: paso 1, imagen 2 de 3 iRulu AX760 Motherboard Replacement, Battery: paso 1, imagen 3 de 3
    • Use a plastic opening tool or metal spudger to free the rear cover.
    • Insert your spudger into the side of your tablet.
    • Crack open each edge and remove the cover.
  2. iRulu AX760 Motherboard Replacement: paso 2, imagen 1 de 1
    • Open your tablet.
  3. iRulu AX760 Motherboard Replacement: paso 3, imagen 1 de 1
    • Take your plastic flat head tool and insert it under the battery.
    • Lift the battery up.
    • Make sure to remove any tape from the battery.
  4. iRulu AX760 Motherboard Replacement: paso 4, imagen 1 de 2 iRulu AX760 Motherboard Replacement: paso 4, imagen 2 de 2
    • Use a soldering iron to remove the solder that connects the black and red wires of the battery to the motherboard.
    • Keep the wires of the battery taught.
    • The iron should only be pressed to the solder for 2-3 seconds max.
    • Be very carful, the soldering iron will be very hot!
    • Visit this link for information about soldering. Cómo soldar y desoldar conexiones
  5. iRulu AX760 Motherboard Replacement: paso 5, imagen 1 de 1
    • Remove your old battery and replace it with the new battery.
  6. iRulu AX760 Motherboard Replacement, Motherboard: paso 6, imagen 1 de 2 iRulu AX760 Motherboard Replacement, Motherboard: paso 6, imagen 2 de 2
    Herramienta utilizada en este paso:
    Plastic Cards
    $2.99
    Comprar
    • There are two thin adhesive strips under the battery that run vertically along the left and right side.
    • Carefully wedge a plastic card or spudger under the battery and along both adhesive strips. Gently work the card or spudger up and down to free the battery.
    • Do not use metal tools, and do not bend or puncture the battery.
  7. iRulu AX760 Motherboard Replacement: paso 7, imagen 1 de 3 iRulu AX760 Motherboard Replacement: paso 7, imagen 2 de 3 iRulu AX760 Motherboard Replacement: paso 7, imagen 3 de 3
    • WARNING: SOLDERING IRONS BECOME EXTREMELY HOT. DO NOT TOUCH
    • For information on soldering and desoldering, check this link.
    • You must desolder several sets of contacts before attempting to remove the motherboard.
    • You must desolder the BAT (battery), LED, SPK (speaker), and ANT (antenna) contacts.
  8. iRulu AX760 Motherboard Replacement: paso 8, imagen 1 de 2 iRulu AX760 Motherboard Replacement: paso 8, imagen 2 de 2
    • Unscrew the motherboard from the screen with the JIS #000 Screwdriver, a Phillips-head type screwdriver
  9. iRulu AX760 Motherboard Replacement: paso 9, imagen 1 de 2 iRulu AX760 Motherboard Replacement: paso 9, imagen 2 de 2
    • Use a plastic spudger to push the tab, releasing the motherboard from the screen. You can now remove the old motherboard.
    • You will not need a metal spudger in order to re-place the motherboard
Conclusión
Adam Schubach
Miembro Desde 03/20/18
123 Reputación
1 Guía escrita
Equipo
IUPUI, Team S6-G4, Baechle Spring 2018 Miembro de IUPUI, Team S6-G4, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G4
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 328
