Saltar al contenido principal
iRobot looj 120 Rear Motor Replacement
Qué necesitas
  1. iRobot looj 120 Rear Motor Replacement, Rear Motor: paso 1, imagen 1 de 1
    • Remove the four exterior screws
Conclusión
Joshua
Miembro Desde 10/24/14
631 Reputación
6 Guías creadas
Equipo
UMass Dartmouth, Team 2-5, Duarte Fall 2014 Miembro de UMass Dartmouth, Team 2-5, Duarte Fall 2014
UMASSD-DUARTE-F14S2G5
3 Miembros
7 Guías creadas
Un comentario
Yeah, to replace the motor just 4 screws and no parts required! Too easy, too easy to write an article that doesn’t help :( Is it just to sell a screwdriver? This would not improve your reputation. You’re wasting our time and wasting your time.
Description: Remove the 4 screws than anyone can see is a good start but did anyone been able to actualy open the body and access inside the box?
I do have an iRobot Looj 330. The body looks very similar to the other model in the range. There are 4 screws, yes but the body in 2 parts doesn’t open that easy. It’s waterproof, I believe there is a trick… Which?
Daniel B - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 249
