Saltar al contenido principal
iRobot Roomba i7 Side Brush Replacement
Qué necesitas
  1. iRobot Roomba i7 Side Brush Replacement, Side Brush: paso 1, imagen 1 de 2 iRobot Roomba i7 Side Brush Replacement, Side Brush: paso 1, imagen 2 de 2
    • Flip the iRobot Roomba i7 so that the underside is facing upwards.
    • Using a Phillips #1 screwdriver, unscrew the 6.27mm-screw in the center of the side brush.
  2. iRobot Roomba i7 Side Brush Replacement: paso 2, imagen 1 de 3 iRobot Roomba i7 Side Brush Replacement: paso 2, imagen 2 de 3 iRobot Roomba i7 Side Brush Replacement: paso 2, imagen 3 de 3
    • After unscrewing the side brush screw, gently pull the brush up, as shown in the picture.
    • If the side brush is difficult to pull, use a plastic opening tool to take it out.
Conclusión
Una persona más ha completado esta guía.
Un comentario
I did all the steps and my brushes are still not turning. Help!
Kathie C. - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 16
Ultimos 30 días: 44
Todo El Tiempo: 5,133
