Saltar al contenido principal
iRobot Roomba i7 Front Bumper Replacement
Qué necesitas
  1. iRobot Roomba i7 Front Bumper Replacement, Front Bumper: paso 1, imagen 1 de 3 iRobot Roomba i7 Front Bumper Replacement, Front Bumper: paso 1, imagen 2 de 3 iRobot Roomba i7 Front Bumper Replacement, Front Bumper: paso 1, imagen 3 de 3
    • Flip the iRobot Roomba i7 so that the underside is facing upwards.
    • Using a Phillips #1 screwdriver, unscrew the 6.27mm screw in the center of the side brush.
    • Using a Phillips #1 screwdriver, unscrew the 5 screws surrounding the bottom cover of the Roomba
  2. iRobot Roomba i7 Front Bumper Replacement: paso 2, imagen 1 de 3 iRobot Roomba i7 Front Bumper Replacement: paso 2, imagen 2 de 3 iRobot Roomba i7 Front Bumper Replacement: paso 2, imagen 3 de 3
    • Use the Philips #1 screw driver to remove the ten, 4.17 mm screws on the dislodged Bumper
  3. iRobot Roomba i7 Front Bumper Replacement: paso 3, imagen 1 de 2 iRobot Roomba i7 Front Bumper Replacement: paso 3, imagen 2 de 2
    • Once removed, readjust the bumper into its appropriate placement.
Conclusión
Una persona más ha completado esta guía.
2 comentarios
My roomba seems to be blind some tomes it starts and just keeps on running into the walls over and over again sometime i rebbot it and it works and other times it doesnt work i dont know what wrong with it. Its a roomba i7+ 3 years old.
John Flannery - Contestar
My Roomba will run until it hits the wall and then runs backwards. Help
beverly vernon - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 34
Ultimos 30 días: 180
Todo El Tiempo: 12,519
