Saltar al contenido principal
iRobot Roomba e5 Maintenance
Qué necesitas
  1. iRobot Roomba e5 Maintenance, Two middle brushes, Edge Sweeping Brush and Dust Bin: paso 1, imagen 1 de 3 iRobot Roomba e5 Maintenance, Two middle brushes, Edge Sweeping Brush and Dust Bin: paso 1, imagen 2 de 3 iRobot Roomba e5 Maintenance, Two middle brushes, Edge Sweeping Brush and Dust Bin: paso 1, imagen 3 de 3
    • To remove the edge sweeping brush, use a Phillips #0 screwdriver to remove the 8 mm screw holding it in place.
  2. iRobot Roomba e5 Maintenance: paso 2, imagen 1 de 3 iRobot Roomba e5 Maintenance: paso 2, imagen 2 de 3 iRobot Roomba e5 Maintenance: paso 2, imagen 3 de 3
    • To remove the two multi-surface brushes, lift the adjacent piece by pressing down the green lever and pulling it up.
    • Then remove the brushes by lifting them by the right side.
  3. iRobot Roomba e5 Maintenance: paso 3, imagen 1 de 1
    • To remove the dust bin, press down on the button with a “trash bin” drawing by the side of the vacuum.
    • While pressing the button, gently pull the dust bin out.
    • When removing the dust bin, dust can tip over the surface and create a mess.
  4. iRobot Roomba e5 Maintenance: paso 4, imagen 1 de 2 iRobot Roomba e5 Maintenance: paso 4, imagen 2 de 2
    • To remove the filter located at the right side of the dust bin, press the filter on top and at the bottom and pull.
  5. iRobot Roomba e5 Maintenance: paso 5, imagen 1 de 3 iRobot Roomba e5 Maintenance: paso 5, imagen 2 de 3 iRobot Roomba e5 Maintenance: paso 5, imagen 3 de 3
    • Clean every part of the vacuum thoroughly with a dust rag or paper towel and Q-tip.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 46
Todo El Tiempo: 1,189
