Saltar al contenido principal
iRobot Roomba 891 Battery Replacement
Qué necesitas
  1. iRobot Roomba 891 Battery Replacement, Battery: paso 1, imagen 1 de 2 iRobot Roomba 891 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Start by flipping your Roomba onto its back on a flat surface.
    • Be sure not to close the side brush bristles in the battery door during reassembly as shown by the handy warning in the second photo.
  2. iRobot Roomba 891 Battery Replacement: paso 2, imagen 1 de 1
    • Unscrew both the 11mm Phillips #2 screws from the battery cover and remove cover from the Roomba.
    • These captive screws are not intended to be removed from the cover.
  3. iRobot Roomba 891 Battery Replacement: paso 3, imagen 1 de 3 iRobot Roomba 891 Battery Replacement: paso 3, imagen 2 de 3 iRobot Roomba 891 Battery Replacement: paso 3, imagen 3 de 3
    • Grasp the tabs on either side of the battery.
    • Remove the battery by pulling up on the tabs.
    • While you're here, check the battery contacts for corrosion or debris.
Conclusión
2 personas más completaron esta guía.
Un comentario
justin i added a push pin to step 1
thomas Wilson - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 8
Ultimos 30 días: 12
Todo El Tiempo: 784
