Saltar al contenido principal
iRobot Roomba 880 Battery Replacement
Qué necesitas
  1. iRobot Roomba 880 Battery Replacement, Battery: paso 1, imagen 1 de 2 iRobot Roomba 880 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Start with your Roomba upside down, with the wheels facing up.
    • Using a JIS driver in #1 size remove the two 15mm screws holding the battery cover in place.
  2. iRobot Roomba 880 Battery Replacement: paso 2, imagen 1 de 1
    • Remove the battery cover and place it off to the side.
  3. iRobot Roomba 880 Battery Replacement: paso 3, imagen 1 de 2 iRobot Roomba 880 Battery Replacement: paso 3, imagen 2 de 2
    • Remove the battery using the green tabs on either side of the battery.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team S17-G4, Banghart Spring 2017 Miembro de Cal Poly, Team S17-G4, Banghart Spring 2017
CPSU-BANGHART-S17S17G4
5 Miembros
5 Guías creadas
Un comentario
I am not trying to be negative here, but if someone needed this guide to understand that a bad battery needed to be replaced, shouldn’t you put that they would need a new battery? According to your directions, they do not need a new battery. As a result, they are going to take out their battery, and put the old one back in. The problem remains. I have never written a guide, so maybe you can only choose parts from iFixit and that is why you did not have one listed in the parts needed, but I would have thought it would have been in the directions.
Anyhow, the guide is still appreciated… please consider this only as constructive feedback to help enhance the product.
Nathan Kramer - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 37
Todo El Tiempo: 4,635
