Saltar al contenido principal
iRobot Roomba 870 Side Brush Motor Replacement
Qué necesitas
  1. iRobot Roomba 870 Side Brush Motor Replacement, Side Brush Motor: paso 1, imagen 1 de 3 iRobot Roomba 870 Side Brush Motor Replacement, Side Brush Motor: paso 1, imagen 2 de 3 iRobot Roomba 870 Side Brush Motor Replacement, Side Brush Motor: paso 1, imagen 3 de 3
    • Turn the Roomba over so that the back side is facing up.
    • Using the Phillips #00 screwdriver, remove the 4.0mm screw in the center of the yellow side brush and lift the part out.
  2. iRobot Roomba 870 Side Brush Motor Replacement: paso 2, imagen 1 de 2 iRobot Roomba 870 Side Brush Motor Replacement: paso 2, imagen 2 de 2
    • Use the Phillips #00 screwdriver to remove the four 3.5mm screws that hold down the battery panel and rear panel.
  3. iRobot Roomba 870 Side Brush Motor Replacement: paso 3, imagen 1 de 2 iRobot Roomba 870 Side Brush Motor Replacement: paso 3, imagen 2 de 2
    • First remove the battery panel, which is the small rectangular.
    • After removing the battery panel, remove the rear panel.
  4. iRobot Roomba 870 Side Brush Motor Replacement: paso 4, imagen 1 de 3 iRobot Roomba 870 Side Brush Motor Replacement: paso 4, imagen 2 de 3 iRobot Roomba 870 Side Brush Motor Replacement: paso 4, imagen 3 de 3
    • Remove the three small 3.5mm screws fastened to the motor housing.
    • After removing the screws, remove the motor housing from the rest of the Roomba.
  5. iRobot Roomba 870 Side Brush Motor Replacement: paso 5, imagen 1 de 3 iRobot Roomba 870 Side Brush Motor Replacement: paso 5, imagen 2 de 3 iRobot Roomba 870 Side Brush Motor Replacement: paso 5, imagen 3 de 3
    • Remove the 2.5mm screw in the center of the motor housing using a Tri-Wing Y1 screwdriver.
    • After removing the screw, remove the top shell casing of the motor housing. Underneath, you will see a white gear with two screws next to it.
  6. iRobot Roomba 870 Side Brush Motor Replacement: paso 6, imagen 1 de 3 iRobot Roomba 870 Side Brush Motor Replacement: paso 6, imagen 2 de 3 iRobot Roomba 870 Side Brush Motor Replacement: paso 6, imagen 3 de 3
    • Remove the two 2.5mm screws in the inner motor housing using a Phillips #00 screwdriver.
    • After removing the two screws, the motor will slide right out the back, and it can be replaced.
Conclusión
2 personas más completaron esta guía.
Equipo
Cal Poly, Team S14-G3, Banghart Spring 2017 Miembro de Cal Poly, Team S14-G3, Banghart Spring 2017
CPSU-BANGHART-S17S14G3
Miembros de 4
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 48
Todo El Tiempo: 3,923
