Saltar al contenido principal
iRobot Roomba 870 Battery Replacement
Qué necesitas
  1. iRobot Roomba 870 Battery Replacement, Battery: paso 1, imagen 1 de 2 iRobot Roomba 870 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • To access the iRobot Roomba 870 battery pack, first flip the Roomba upside down.
    • Then find the battery pack cover that is located in the space between the caster wheel, side brush, and vacuum.
    • Use a Phillips #0 screwdriver to remove the two 3.5mm screws on the battery pack cover.
  2. iRobot Roomba 870 Battery Replacement: paso 2, imagen 1 de 3 iRobot Roomba 870 Battery Replacement: paso 2, imagen 2 de 3 iRobot Roomba 870 Battery Replacement: paso 2, imagen 3 de 3
    • Remove the loose battery cover to access the battery compartment.
    • Use the yellow tabs, located on the short ends of the battery pack, to gently pull the battery up and out of its slot.
Conclusión
Follow the steps in reverse order for reassembly.
2 personas más completaron esta guía.
Vitek Harvey
Miembro Desde 04/26/17
149 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S14-G3, Banghart Spring 2017 Miembro de Cal Poly, Team S14-G3, Banghart Spring 2017
CPSU-BANGHART-S17S14G3
Miembros de 4
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 37
Todo El Tiempo: 3,565
