Saltar al contenido principal
iRobot Roomba 860 Filter Replacement
  1. iRobot Roomba 860 Filter Replacement, Filter: paso 1, imagen 1 de 3 iRobot Roomba 860 Filter Replacement, Filter: paso 1, imagen 2 de 3 iRobot Roomba 860 Filter Replacement, Filter: paso 1, imagen 3 de 3
    • Orient the Roomba so that the device is on its wheels and the words can be read from left to right.
    • Press the large button on the Roomba that is located closest to you.
    • Pull towards you to remove dust bin.
    • Now place dust bin flat with the large button towards you.
  2. iRobot Roomba 860 Filter Replacement: paso 2, imagen 1 de 2 iRobot Roomba 860 Filter Replacement: paso 2, imagen 2 de 2
    • With the dust bin completely detached from the Roomba, press the tab that is located on your right.
    • Now lift red plastic cover to begin removing the filter.
  3. iRobot Roomba 860 Filter Replacement: paso 3, imagen 1 de 2 iRobot Roomba 860 Filter Replacement: paso 3, imagen 2 de 2
    • Using the yellow ribbon that is located at the top of the filter, pull it towards you.
    • Carefully remove the used filter.
Conclusión
Stephen Yezukevicz
Miembro Desde 11/06/18
193 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 296
