Introducción
The side brush is responsible for cleaning the baseboard or the sides of objects it encounters.
Qué necesitas
Flip the Roomba over so that the wheels are facing up and the dust tray is closest to you.
Using the J1 Phillips screwdriver, locate and unscrew the two 11mm phillips screws above the brushes on the battery panel.
Remove the plastic plate from the battery box.
Using the J1 Philips Screwdriver, remove the 15.5 mm screw located in the center of the side brush.
Remove the brush by pulling upwards.
