Saltar al contenido principal
iRobot Roomba 770 Side Brush Motor Replacement
Qué necesitas
  1. iRobot Roomba 770 Side Brush Motor Replacement, Battery: paso 1, imagen 1 de 2 iRobot Roomba 770 Side Brush Motor Replacement, Battery: paso 1, imagen 2 de 2
    • Flip the Roomba over so that the wheels are facing up and the dust tray is closest to you.
    • Using the J1 Phillips screwdriver, locate and unscrew the two 11mm phillips screws above the brushes on the battery panel.
    • Remove the plastic plate from the battery box.
  2. iRobot Roomba 770 Side Brush Motor Replacement: paso 2, imagen 1 de 2 iRobot Roomba 770 Side Brush Motor Replacement: paso 2, imagen 2 de 2
    • Locate the 2 green tabs on the left and right of the big yellow battery.
    • Grab the tabs with your hands and lift straight upward.
  3. iRobot Roomba 770 Side Brush Motor Replacement, Side Brush Motor: paso 3, imagen 1 de 1
    • Using the J1 Philips Screwdriver, remove the 15.5 mm screw located in the center of the side brush.
    • Remove the brush by pulling upwards.
    • Do not lean directly over the brush when attempting to remove. Removing the brush requires a firm pull and may release suddenly.
  4. iRobot Roomba 770 Side Brush Motor Replacement: paso 4, imagen 1 de 2 iRobot Roomba 770 Side Brush Motor Replacement: paso 4, imagen 2 de 2
    • Using the J1 Philips Screwdriver, remove the two 15.5 mm screws located on the bottom of the plate covering the bottom of the roomba.
    • Lift upwards to remove the bottom plate.
  5. iRobot Roomba 770 Side Brush Motor Replacement: paso 5, imagen 1 de 2 iRobot Roomba 770 Side Brush Motor Replacement: paso 5, imagen 2 de 2
    • Using the J1 Philips Screwdriver, remove the two gold 15.5 mm screws located on the blue plastic module the side brush had previously been attached too.
    • Lift the blue module upwards. The module contains the motor for the side brush.
Conclusión
Ashley Woods
Miembro Desde 10/06/16
347 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 15-3, Livingston Fall 2016 Miembro de Cal Poly, Team 15-3, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G3
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 12
Todo El Tiempo: 2,638
