Saltar al contenido principal
iRobot Roomba 690 Drive Wheels Replacement
Qué necesitas
  1. iRobot Roomba 690 Drive Wheels Replacement, Spinning Brush: paso 1, imagen 1 de 1
    • Place the Roomba upside down so that the wheels and brushes are facing upward.
  2. iRobot Roomba 690 Drive Wheels Replacement: paso 2, imagen 1 de 3 iRobot Roomba 690 Drive Wheels Replacement: paso 2, imagen 2 de 3 iRobot Roomba 690 Drive Wheels Replacement: paso 2, imagen 3 de 3
    • Loosen the captive screw in the spinning brush using a Phillips #0 screwdriver.
    • Remove the spinning brush from the vacuum.
  3. iRobot Roomba 690 Drive Wheels Replacement, Battery: paso 3, imagen 1 de 1
    • Remove the four 6.4 mm screws from the bottom of the Roomba using a Phillips #0 screwdriver.
    • They are labeled with triangular arrows next to them on the cover.
  4. iRobot Roomba 690 Drive Wheels Replacement: paso 4, imagen 1 de 1
    • Lift the bottom cover up from the rest of the Roomba.
  5. iRobot Roomba 690 Drive Wheels Replacement: paso 5, imagen 1 de 3 iRobot Roomba 690 Drive Wheels Replacement: paso 5, imagen 2 de 3 iRobot Roomba 690 Drive Wheels Replacement: paso 5, imagen 3 de 3
    • Lift out the battery by pulling up on the two flexible tabs that are attached to the left and right sides.
  6. iRobot Roomba 690 Drive Wheels Replacement, Drive Wheels: paso 6, imagen 1 de 2 iRobot Roomba 690 Drive Wheels Replacement, Drive Wheels: paso 6, imagen 2 de 2
    • Each drive wheel is labeled left and right.
    • Remove three 12 mm screws from each drive wheel using a Phillips #0 screwdriver.
    • Remove the drive wheels from the vacuum.
Conclusión
John Galvin
Miembro Desde 03/23/22
584 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 21
Todo El Tiempo: 429
