Saltar al contenido principal
iRobot Roomba 655 Pet Series Side Brush and Back Panel Removal
Qué necesitas
  1. iRobot Roomba 655 Pet Series Side Brush and Back Panel Removal, Removing the Side Brush: paso 1, imagen 1 de 2 iRobot Roomba 655 Pet Series Side Brush and Back Panel Removal, Removing the Side Brush: paso 1, imagen 2 de 2
    • Flip the device over onto its back.
    • Find the side brush, and unscrew the single screw that connects to brush motor by using the Phillips head #2 screwdriver.
    • This screw doesn't completely come out of the yellow side brush.
  2. iRobot Roomba 655 Pet Series Side Brush and Back Panel Removal, Removing the Back Panel: paso 2, imagen 1 de 2 iRobot Roomba 655 Pet Series Side Brush and Back Panel Removal, Removing the Back Panel: paso 2, imagen 2 de 2
    • Using a Phillips #1 screwdriver, remove the four screws on the back panel.
    • Once the screws are loose gently pry the back plate away from the body by using the spudger tool.
    • The screws don't completely come out of the panel, but it will still come apart once unscrewed.
Conclusión
Matt Davis
Miembro Desde 01/22/15
1,642 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 21-20, Maness Winter 2015 Miembro de Cal Poly, Team 21-20, Maness Winter 2015
CPSU-MANESS-W15S21G20
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 18
Todo El Tiempo: 1,588
