Introducción
This motor is what keeps that yellow side brush turning, picking up hairs and things dust in those hard to reach places.
Qué necesitas
First start by removing the two - 6mm screws with your Phillips head #1, that unlock the motor from your Roomba
Pull the brush motor out
Next, with the same head remove the screw holding the plastic housing together
Carefully pry the gear box open by placing a flat head screwdriver in the slot
Removing these two screws will allow you to access the motor (use the same head as before)
2 personas más completaron esta guía.
