Saltar al contenido principal
iRobot Roomba 655 Pet Series Front Bumper Replacement
Qué necesitas
  1. iRobot Roomba 655 Pet Series Front Bumper  Replacement, Front Bumper: paso 1, imagen 1 de 2 iRobot Roomba 655 Pet Series Front Bumper  Replacement, Front Bumper: paso 1, imagen 2 de 2
    • Remove the ten 11mm screws that hold the front bumper to the plastic bumper protector with your Phillips #1 screwdriver.
    • Pull the plastic bumper protector up and off of the bumper.
  2. iRobot Roomba 655 Pet Series Front Bumper  Replacement: paso 2, imagen 1 de 3 iRobot Roomba 655 Pet Series Front Bumper  Replacement: paso 2, imagen 2 de 3 iRobot Roomba 655 Pet Series Front Bumper  Replacement: paso 2, imagen 3 de 3
    • Flip the Roomba back over, so you are viewing the top.
    • Pull up on the front bumper to remove it.
    • Be careful not to pull too hard because there is wiring attached to the bumper.
    • Remove the two 7mm screws with your Phillips #1 screwdriver, holding the wire sensors in place to the front bumper.
Conclusión
Rhett
Miembro Desde 01/22/15
1,329 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 21-20, Maness Winter 2015 Miembro de Cal Poly, Team 21-20, Maness Winter 2015
CPSU-MANESS-W15S21G20
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 12
Todo El Tiempo: 4,320
