Saltar al contenido principal
iRobot Roomba 655 Pet Series Display Replacement
Qué necesitas
  1. iRobot Roomba 655 Pet Series Display  Replacement, Front Face Plate: paso 1, imagen 1 de 2 iRobot Roomba 655 Pet Series Display  Replacement, Front Face Plate: paso 1, imagen 2 de 2
    • Remove the dust bin by pushing on the button for the dust bin removal
    • Pull the dust bin out
  2. iRobot Roomba 655 Pet Series Display  Replacement: paso 2, imagen 1 de 2 iRobot Roomba 655 Pet Series Display  Replacement: paso 2, imagen 2 de 2
    • Pull up on the silver handle to release the top protectant plastic
    • Remove the top plastic carefully
  3. iRobot Roomba 655 Pet Series Display  Replacement, Front Bumper: paso 3, imagen 1 de 2 iRobot Roomba 655 Pet Series Display  Replacement, Front Bumper: paso 3, imagen 2 de 2
    • Remove the ten 11mm screws that hold the front bumper to the plastic bumper protector with your Phillips #1 screwdriver.
    • Pull the plastic bumper protector up and off of the bumper.
  4. iRobot Roomba 655 Pet Series Display  Replacement: paso 4, imagen 1 de 3 iRobot Roomba 655 Pet Series Display  Replacement: paso 4, imagen 2 de 3 iRobot Roomba 655 Pet Series Display  Replacement: paso 4, imagen 3 de 3
    • Flip the Roomba back over, so you are viewing the top.
    • Pull up on the front bumper to remove it.
    • Be careful not to pull too hard because there is wiring attached to the bumper.
    • Remove the two 7mm screws with your Phillips #1 screwdriver, holding the wire sensors in place to the front bumper.
  5. iRobot Roomba 655 Pet Series Display  Replacement, Internal Faceplate: paso 5, imagen 1 de 3 iRobot Roomba 655 Pet Series Display  Replacement, Internal Faceplate: paso 5, imagen 2 de 3 iRobot Roomba 655 Pet Series Display  Replacement, Internal Faceplate: paso 5, imagen 3 de 3
    • The outside six - 10mm screws and the inside set of four - 10mm screws are the same here, use your Phillips head #2 to remove them
    • Use your Phillips head #0 to remove the one - 7mm bottom center screw
    • Use your Phillips head #2 to remove the two - 8mm screws by the handle
    • Push down the two release points to pull the plastic piece up
    • Pull the plastic piece up
  6. iRobot Roomba 655 Pet Series Display  Replacement, Display: paso 6, imagen 1 de 3 iRobot Roomba 655 Pet Series Display  Replacement, Display: paso 6, imagen 2 de 3 iRobot Roomba 655 Pet Series Display  Replacement, Display: paso 6, imagen 3 de 3
    • Pull the silver tab, and clear tinted display off
    • Remove the 4 - 9mm screws holding the display with your Phillips head #0
  7. iRobot Roomba 655 Pet Series Display  Replacement: paso 7, imagen 1 de 3 iRobot Roomba 655 Pet Series Display  Replacement: paso 7, imagen 2 de 3 iRobot Roomba 655 Pet Series Display  Replacement: paso 7, imagen 3 de 3
    • Remove the display
    • Remove the plastic protectant film from the motherboard
Conclusión
Una persona más ha completado esta guía.
Rhett
Miembro Desde 01/22/15
1,329 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 21-20, Maness Winter 2015 Miembro de Cal Poly, Team 21-20, Maness Winter 2015
CPSU-MANESS-W15S21G20
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 864
