Saltar al contenido principal
iRobot Roomba 655 Pet Series Battery Replacement
Qué necesitas
  1. iRobot Roomba 655 Pet Series Battery Replacement, Removing the Side Brush: paso 1, imagen 1 de 2 iRobot Roomba 655 Pet Series Battery Replacement, Removing the Side Brush: paso 1, imagen 2 de 2
    • Flip the device over onto its back.
    • Find the side brush, and unscrew the single screw that connects to brush motor by using the Phillips head #2 screwdriver.
    • This screw doesn't completely come out of the yellow side brush.
  2. iRobot Roomba 655 Pet Series Battery Replacement, Removing the Back Panel: paso 2, imagen 1 de 2 iRobot Roomba 655 Pet Series Battery Replacement, Removing the Back Panel: paso 2, imagen 2 de 2
    • Using a Phillips #1 screwdriver, remove the four screws on the back panel.
    • Once the screws are loose gently pry the back plate away from the body by using the spudger tool.
    • The screws don't completely come out of the panel, but it will still come apart once unscrewed.
  3. iRobot Roomba 655 Pet Series Battery Replacement, Removing the Battery: paso 3, imagen 1 de 3 iRobot Roomba 655 Pet Series Battery Replacement, Removing the Battery: paso 3, imagen 2 de 3 iRobot Roomba 655 Pet Series Battery Replacement, Removing the Battery: paso 3, imagen 3 de 3
    • Grab the two pieces of green tape with your thumb and index finger
    • Pull up on the battery in an upwards direction to remove it
  4. iRobot Roomba 655 Pet Series Battery Replacement, Battery Contact Points: paso 4, imagen 1 de 2 iRobot Roomba 655 Pet Series Battery Replacement, Battery Contact Points: paso 4, imagen 2 de 2
    • These are the contact points on the Roomba for the battery
    • These are the contact points on the battery
    • If these contact points are dirty, they can be cleaned with a moist microfiber cloth (distilled water recommended)
Conclusión
12 personas más completaron esta guía.
Matt Davis
Miembro Desde 01/22/15
1,642 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 21-20, Maness Winter 2015 Miembro de Cal Poly, Team 21-20, Maness Winter 2015
CPSU-MANESS-W15S21G20
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 42
Todo El Tiempo: 12,831
