Saltar al contenido principal
iRobot Roomba 650 Side Brush and Bottom Panel Replacement
Qué necesitas
  1. iRobot Roomba 650 Side Brush and Bottom Panel Replacement, Removing the Side Brush: paso 1, imagen 1 de 2 iRobot Roomba 650 Side Brush and Bottom Panel Replacement, Removing the Side Brush: paso 1, imagen 2 de 2
    • With the Roomba upside down and turned off, use the Phillip's 02 screwdriver to remove the one 3.5 mm screw from the center of the side-brush.
    • Set the screw aside and pull the brush out.
  2. iRobot Roomba 650 Side Brush and Bottom Panel Replacement, Bottom Panel Removal: paso 2, imagen 1 de 2 iRobot Roomba 650 Side Brush and Bottom Panel Replacement, Bottom Panel Removal: paso 2, imagen 2 de 2
    • Unscrew the four screws that hold the bottom panel using the Phillips 02 screwdriver.
    • The screws will not come out of the bottom panel. They were designed to become loose but not be removed. This prevents you from losing them, and prevents the Roomba from sucking them up if they came out during cleaning.
    • Once you are sure that all the screws have been loosened as much as possible, then lift the bottom panel up off the Roomba.
Conclusión
4 personas más completaron esta guía.
Charles Ward
Miembro Desde 01/22/15
1,011 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 19-7, Maness Winter 2015 Miembro de Cal Poly, Team 19-7, Maness Winter 2015
CPSU-MANESS-W15S19G7
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 14
Todo El Tiempo: 4,628
