Saltar al contenido principal
iRobot Roomba 650 Battery Replacement
Qué necesitas
  1. iRobot Roomba 650 Battery Replacement, Removing the Side Brush: paso 1, imagen 1 de 2 iRobot Roomba 650 Battery Replacement, Removing the Side Brush: paso 1, imagen 2 de 2
    • With the Roomba upside down and turned off, use the Phillip's 02 screwdriver to remove the one 3.5 mm screw from the center of the side-brush.
    • Set the screw aside and pull the brush out.
  2. iRobot Roomba 650 Battery Replacement, Bottom Panel Removal: paso 2, imagen 1 de 2 iRobot Roomba 650 Battery Replacement, Bottom Panel Removal: paso 2, imagen 2 de 2
    • Unscrew the four screws that hold the bottom panel using the Phillips 02 screwdriver.
    • The screws will not come out of the bottom panel. They were designed to become loose but not be removed. This prevents you from losing them, and prevents the Roomba from sucking them up if they came out during cleaning.
    • Once you are sure that all the screws have been loosened as much as possible, then lift the bottom panel up off the Roomba.
  3. iRobot Roomba 650 Battery Replacement, Battery: paso 3, imagen 1 de 1
    • Once the side brush and bottom panel are out of the way, simply grasp the battery by the two green flaps and pull it out.
    • In the unlikely event that the battery has leaked acid, avoid all contact with it and any surfaces it has affected. Wear protective gloves and wipe up any residue with a paper towel. Secure the battery in a plastic bag and dispose of it properly.
    • If you get battery acid on your skin or in your eye, flush immediately with water and seek medical attention.
Conclusión
17 personas más completaron esta guía.
Charles Ward
Miembro Desde 01/22/15
975 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 19-7, Maness Winter 2015 Miembro de Cal Poly, Team 19-7, Maness Winter 2015
CPSU-MANESS-W15S19G7
4 Miembros
6 Guías creadas
Un comentario
We thought we were going to have to put Boohya down (our toddler named it that) so he is very happy that by simply replacing the battery we brought him back to life! Thanks! $17 well spent.
Deedra Wollert - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 25
Ultimos 30 días: 80
Todo El Tiempo: 17,851
