Saltar al contenido principal
iRobot Roomba 630 Top Bumper Infrared Sensor Replacement
Qué necesitas
  1. iRobot Roomba 630 Top Bumper Infrared Sensor Replacement, Front Sensor: paso 1, imagen 1 de 2 iRobot Roomba 630 Top Bumper Infrared Sensor Replacement, Front Sensor: paso 1, imagen 2 de 2
    • Press the bin button and pull the bin out.
  2. iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: paso 2, imagen 1 de 2 iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: paso 2, imagen 2 de 2
    • FIip the device over and unscrew the side brush screw using the Phillips #2 screwdriver.
  3. iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: paso 3, imagen 1 de 2 iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: paso 3, imagen 2 de 2
    • Unscrew the (4) four back plate screws using the Phillips #2 screwdriver.
    • Lift the back plate off of the device.
  4. iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: paso 4, imagen 1 de 2 iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: paso 4, imagen 2 de 2
    • Unscrew the screws on the bottom of the front bumper.
  5. iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: paso 5, imagen 1 de 2 iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: paso 5, imagen 2 de 2
    • Flip the device over and lift the front bumper up and off.
    • Lift with care so the sensor wires aren't damaged.
  6. iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: paso 6, imagen 1 de 2 iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: paso 6, imagen 2 de 2
    • Flip the Roomba back over and unscrew the 2 screws that connect the sensor to the bumper.
  7. iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: paso 7, imagen 1 de 3 iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: paso 7, imagen 2 de 3 iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: paso 7, imagen 3 de 3
    • Flip Roomba back over and pry the top cover off.
    • Unscrew the screws to the top plate and lift off.
  8. iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: paso 8, imagen 1 de 3 iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: paso 8, imagen 2 de 3 iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: paso 8, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers or another tool to push up on the insert while gently pulling the sensor out by its wires.
    • Remove the sensor.
Conclusión
4 personas más completaron esta guía.
Jeffrey Rook
Miembro Desde 10/03/17
125 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S5-G3, Walkup Fall 2017 Miembro de USF Tampa, Team S5-G3, Walkup Fall 2017
USFT-WALKUP-F17S5G3
4 Miembros
7 Guías creadas
4 comentarios
Exact same instructions for a Roomba 690. Great guide and much cheaper than sending it in for out of warranty repair at $135 bucks!!!
Jeff Brockway - Contestar
Outstanding! I would only add to note position of the 12 top plate screws as they are removed since 3 are smaller/shorter (although not noticeably so) and need to be returned to their exact location. I would not call this difficult. Simply tedious. Thank you very much for the instrucitons.
Linda Marsh - Contestar
Thanks for this. Roomba wanted me to send my unit in for repairs costing $130. I bought a replacement Rcon at eBay for $10. Turned out, as others have posted, the red wire was broken! That’s on Roomba!! Works like new, will repair the red wire, and save the rcon for future use.
natenaybore - Contestar
This is very helpful! Thank you. In my case, all the 3 wires were thorn from the sensor head. I could resolver them but I can’t tell which is which. Can someone post where the 3 wires connect in the sensor head? There are 3 leads coming out of the sensor head but no insulation left on them so I can match with the correct wire. Much appreciated!
GandaFix - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 39
Ultimos 30 días: 104
Todo El Tiempo: 9,427
