Introducción
The main brush easily acquires a lot of dust and other things which may cause it to lose its potency; replacing it will make the Roomba more effective. There is no danger in this replacement and no real hard work.
Qué necesitas
Flip the Roomba upside down. Using the Phillips #0 screwdriver, carefully remove the 5 mm screw holding the brush in place.
Remove the four 10mm screws with a Phillips #1 screwdriver. Gently lift off the external covering for the Roomba's underside.
Una persona más ha completado esta guía.
