Saltar al contenido principal
iRobot Roomba 595 Pet Series Battery Replacement
Qué necesitas
  1. iRobot Roomba 595 Pet Series Battery Replacement, Secondary Brush: paso 1, imagen 1 de 1
    • Flip the Roomba upside down. Using the Phillips #0 screwdriver, carefully remove the 5 mm screw holding the brush in place.
  2. iRobot Roomba 595 Pet Series Battery Replacement: paso 2, imagen 1 de 1
    • Gently pull the brush up and remove it from the device.
  3. iRobot Roomba 595 Pet Series Battery Replacement, Battery: paso 3, imagen 1 de 1
    • Unscrew the four 10mm screws on the underside of the Roomba using a Phillips #1 screwdriver.
  4. iRobot Roomba 595 Pet Series Battery Replacement: paso 4, imagen 1 de 1
    • Remove the bottom frame of the device.
  5. iRobot Roomba 595 Pet Series Battery Replacement: paso 5, imagen 1 de 1
    • Grab the green tape attached to the end of the battery and remove the battery from the device.
Conclusión
5 personas más completaron esta guía.
Equipo
USF Tampa, Team S10-G5, Thompson Fall 2017 Miembro de USF Tampa, Team S10-G5, Thompson Fall 2017
USFT-THOMPSON-F17S10G5
3 Miembros
5 Guías creadas
2 comentarios
Pls, can i charge the roomba directly, because the base is not working??
elie moussa - Contestar
Yes I think so, mine can
Big builder - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 17
Ultimos 30 días: 62
Todo El Tiempo: 5,158
