Saltar al contenido principal
iRobot Roomba 595 Pet Series Side Brush Motor Replacement
Qué necesitas
  1. iRobot Roomba 595 Pet Series  Side Brush Motor Replacement, Secondary Brush: paso 1, imagen 1 de 1
    • Flip the Roomba upside down. Using the Phillips #0 screwdriver, carefully remove the 5 mm screw holding the brush in place.
  2. iRobot Roomba 595 Pet Series  Side Brush Motor Replacement: paso 2, imagen 1 de 1
    • Gently pull the brush up and remove it from the device.
  3. iRobot Roomba 595 Pet Series  Side Brush Motor Replacement, Side Brush Motor: paso 3, imagen 1 de 2 iRobot Roomba 595 Pet Series  Side Brush Motor Replacement, Side Brush Motor: paso 3, imagen 2 de 2
    • Unscrew the four 10mm screws on the underside of the Roomba with a Phillips #1 screwdriver.
    • Lift the external underside cover accordingly.
  4. iRobot Roomba 595 Pet Series  Side Brush Motor Replacement: paso 4, imagen 1 de 1
    • Use the Phillips #0 screwdriver bit to remove the three 15mm screws.
  5. iRobot Roomba 595 Pet Series  Side Brush Motor Replacement: paso 5, imagen 1 de 2 iRobot Roomba 595 Pet Series  Side Brush Motor Replacement: paso 5, imagen 2 de 2
    • Remove the motor from the blue casing.
Conclusión
Equipo
USF Tampa, Team S10-G5, Thompson Fall 2017 Miembro de USF Tampa, Team S10-G5, Thompson Fall 2017
USFT-THOMPSON-F17S10G5
3 Miembros
5 Guías creadas
2 comentarios
I changed the motor and still does not work.
Jose - Contestar
I changed the motor and still did not work.
Jose - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 730
