Saltar al contenido principal
iRobot Roomba 551 Bumper Sensor Replacement
Qué necesitas
  1. iRobot Roomba 551 Bumper Sensor Replacement, Side Brush: paso 1, imagen 1 de 1
    • Place your Roomba upside-down on a hard surface.
  2. iRobot Roomba 551 Bumper Sensor Replacement: paso 2, imagen 1 de 1
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  3. iRobot Roomba 551 Bumper Sensor Replacement: paso 3, imagen 1 de 1
    • Gently pull upwards on the brush to remove it.
  4. iRobot Roomba 551 Bumper Sensor Replacement, Bottom Plate: paso 4, imagen 1 de 1
    • Rotate the Roomba upside-down so the bottom is facing towards you.
  5. iRobot Roomba 551 Bumper Sensor Replacement: paso 5, imagen 1 de 2 iRobot Roomba 551 Bumper Sensor Replacement: paso 5, imagen 2 de 2
    • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
  6. iRobot Roomba 551 Bumper Sensor Replacement: paso 6, imagen 1 de 1
    • Carefully lift the bottom plate.
    • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
  7. iRobot Roomba 551 Bumper Sensor Replacement, Bumper: paso 7, imagen 1 de 3 iRobot Roomba 551 Bumper Sensor Replacement, Bumper: paso 7, imagen 2 de 3 iRobot Roomba 551 Bumper Sensor Replacement, Bumper: paso 7, imagen 3 de 3
    • With a Phillips #1 screwdriver, remove the ten 12mm screws located along the bottom of the bumper.
  8. iRobot Roomba 551 Bumper Sensor Replacement: paso 8, imagen 1 de 1
    • Lift the bottom cover and set it to the side.
  9. iRobot Roomba 551 Bumper Sensor Replacement: paso 9, imagen 1 de 2 iRobot Roomba 551 Bumper Sensor Replacement: paso 9, imagen 2 de 2
    • Flip the Roomba over, grasp the bumper, and gently lift to remove.
    • The battery is not secured in place once the bottom plate has been removed, and may fall out when the Roomba is turned right-side up.
  10. iRobot Roomba 551 Bumper Sensor Replacement, Bumper Sensor: paso 10, imagen 1 de 1
    • Flip the Roomba so that the bottom is facing you.
  11. iRobot Roomba 551 Bumper Sensor Replacement: paso 11, imagen 1 de 2 iRobot Roomba 551 Bumper Sensor Replacement: paso 11, imagen 2 de 2
    • Remove the two 5mm screws located near the center of the bumper using a Phillips #1 screwdriver.
  12. iRobot Roomba 551 Bumper Sensor Replacement: paso 12, imagen 1 de 1
    • Pull gently on the bottom of the sensor to remove.
  13. iRobot Roomba 551 Bumper Sensor Replacement: paso 13, imagen 1 de 3 iRobot Roomba 551 Bumper Sensor Replacement: paso 13, imagen 2 de 3 iRobot Roomba 551 Bumper Sensor Replacement: paso 13, imagen 3 de 3
    • Flip the bumper over and lift the sensor from its compartment.
    • You are now free to replace the bumper sensor.
Conclusión
4 personas más completaron esta guía.
Cody Rhoads
Miembro Desde 01/16/14
348 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 13-14, Regan Winter 2014 Miembro de Cal Poly, Team 13-14, Regan Winter 2014
CPSU-REGAN-W14S13G14
4 Miembros
19 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 4,679
