Saltar al contenido principal
iRobot Roomba 551 Brushes Replacement
Qué necesitas
  1. iRobot Roomba 551 Brushes Replacement, Side Brush: paso 1, imagen 1 de 1
    • Place your Roomba upside-down on a hard surface.
  2. iRobot Roomba 551 Brushes Replacement: paso 2, imagen 1 de 1
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  3. iRobot Roomba 551 Brushes Replacement: paso 3, imagen 1 de 1
    • Gently pull upwards on the brush to remove it.
  4. iRobot Roomba 551 Brushes Replacement, Bottom Plate: paso 4, imagen 1 de 1
    • Rotate the Roomba upside-down so the bottom is facing towards you.
  5. iRobot Roomba 551 Brushes Replacement: paso 5, imagen 1 de 2 iRobot Roomba 551 Brushes Replacement: paso 5, imagen 2 de 2
    • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
  6. iRobot Roomba 551 Brushes Replacement: paso 6, imagen 1 de 1
    • Carefully lift the bottom plate.
    • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
  7. iRobot Roomba 551 Brushes Replacement, Brushes: paso 7, imagen 1 de 2 iRobot Roomba 551 Brushes Replacement, Brushes: paso 7, imagen 2 de 2
    • Pinch the yellow tabs on the sides of the brush cage and lift up to open.
  8. iRobot Roomba 551 Brushes Replacement: paso 8, imagen 1 de 3 iRobot Roomba 551 Brushes Replacement: paso 8, imagen 2 de 3 iRobot Roomba 551 Brushes Replacement: paso 8, imagen 3 de 3
    • Grab each brush and lift upwards to remove.
Conclusión
John McTigue
Miembro Desde 01/31/14
331 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 13-14, Regan Winter 2014 Miembro de Cal Poly, Team 13-14, Regan Winter 2014
CPSU-REGAN-W14S13G14
4 Miembros
19 Guías creadas
2 comentarios
Should be no need to remove the back plate. Just open the brush cage and lift out the brushes
Gunnar Nybraten - Contestar
I did all that, bought a new brush cage and it is still announcing error 2-clean brushes.
Christa Eads - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 9
Ultimos 7 días: 82
Ultimos 30 días: 372
Todo El Tiempo: 7,238
