Introducción
This guide explains how to remove the brush case from your Roomba.
  1. Place your Roomba upside-down on a hard surface.
    • Place your Roomba upside-down on a hard surface.
  2. While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  3. Gently pull upwards on the brush to remove it.
    • Gently pull upwards on the brush to remove it.
  4. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  5. Rotate the Roomba upside-down so the bottom is facing towards you.
    • Rotate the Roomba upside-down so the bottom is facing towards you.
  6. Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place. Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
    • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
  7. Carefully lift the bottom plate.
    • Carefully lift the bottom plate.
    • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
  8. Push on the dirt bin release button, and pull gently.
    • Push on the dirt bin release button, and pull gently.
  9. Use a Phillips #1 screwdriver to loosen the 4 captive screws around the case .
    • Use a Phillips #1 screwdriver to loosen the 4 captive screws around the case .
  10. Grab the brush case and pull upwards to remove.
    • Grab the brush case and pull upwards to remove.
Conclusión
Una persona más ha completado esta guía.
John McTigue
Miembro Desde 31/01/14
331 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 13-14, Regan Winter 2014 Miembro de Cal Poly, Team 13-14, Regan Winter 2014
CPSU-REGAN-W14S13G14
4 Miembros
13 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 496
