Saltar al contenido principal
iRobot Roomba 551 Battery Replacement
Qué necesitas
  1. iRobot Roomba 551  Battery Replacement, Side Brush: paso 1, imagen 1 de 1
    • Place your Roomba upside-down on a hard surface.
  2. iRobot Roomba 551  Battery Replacement: paso 2, imagen 1 de 1
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  3. iRobot Roomba 551  Battery Replacement: paso 3, imagen 1 de 1
    • Gently pull upwards on the brush to remove it.
  4. iRobot Roomba 551  Battery Replacement, Bottom Plate: paso 4, imagen 1 de 1
    • Rotate the Roomba upside-down so the bottom is facing towards you.
  5. iRobot Roomba 551  Battery Replacement: paso 5, imagen 1 de 2 iRobot Roomba 551  Battery Replacement: paso 5, imagen 2 de 2
    • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
  6. iRobot Roomba 551  Battery Replacement: paso 6, imagen 1 de 1
    • Carefully lift the bottom plate.
    • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
  7. iRobot Roomba 551  Battery Replacement, Battery: paso 7, imagen 1 de 2 iRobot Roomba 551  Battery Replacement, Battery: paso 7, imagen 2 de 2
    • Lift and remove the old battery by pulling the tabs on both sides.
    • Gently replace with a new battery.
Conclusión
6 personas más completaron esta guía.
Equipo
Cal Poly, Team 13-14, Regan Winter 2014 Miembro de Cal Poly, Team 13-14, Regan Winter 2014
CPSU-REGAN-W14S13G14
Miembros de 4
19 Guías creadas
Un comentario
Thank you Deborah!
James - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 16
Ultimos 30 días: 60
Todo El Tiempo: 10,876
