Saltar al contenido principal
iRobot Roomba 4160 Spinning Edge Brush Replacement
Qué necesitas
  1. iRobot Roomba 4160 Spinning Edge Brush Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the Roomba is turned off to avoid an electric shock.
    • Turn the Roomba upside down, and place it so that the underside is exposed. The wheels and brushes should be visible.
    • Do not attempt to open up the yellow battery pack. You may get shocked or burned by the battery acid.
  2. iRobot Roomba 4160 Spinning Edge Brush Replacement: paso 2, imagen 1 de 2 iRobot Roomba 4160 Spinning Edge Brush Replacement: paso 2, imagen 2 de 2
    • Identify the yellow plastic rectangular battery, directly to the right of the spinning brush.
    • Place your index fingers on the small rectangular plastic tabs on both sides of the battery. Push the tabs in until the battery comes loose.
    • Pull battery out using your fingers.
  3. iRobot Roomba 4160 Spinning Edge Brush Replacement, Spinning Edge Brush: paso 3, imagen 1 de 2 iRobot Roomba 4160 Spinning Edge Brush Replacement, Spinning Edge Brush: paso 3, imagen 2 de 2
    • Locate the spinning brush that is directly to the left of the rectangular pocket for the battery pack.
    • Unscrew the 7.2mm Phillips #1 screw from the spinning brush.
  4. iRobot Roomba 4160 Spinning Edge Brush Replacement: paso 4, imagen 1 de 1
    • Gently pull the spinning brush upwards to remove it.
Conclusión
Equipo
Cal Poly, Team 6-4, Forte Spring 2014 Miembro de Cal Poly, Team 6-4, Forte Spring 2014
CPSU-FORTE-S14S6G4
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 11
Todo El Tiempo: 367
