Saltar al contenido principal
iRobot Roomba 4160 Brush Replacement
  1. iRobot Roomba 4160 Brush Replacement, Brush Guard: paso 1, imagen 1 de 1
    • Make sure the Roomba is turned off to prevent injury.
    • Turn the Roomba upside down so that the underside is exposed. The wheels and brushes should be visible.
    • Identify the brush guard, which is the black rectangular frame that the metal rods are attached to.
  2. iRobot Roomba 4160 Brush Replacement: paso 2, imagen 1 de 1
    • Locate the 2 small rectangular yellow tabs on either side of the brush guard, directly adjacent to the blue flap.
    • Place index fingers on both tabs, and apply slight pressure in the direction of the yellow battery pack.
    • While you are applying pressure, the guard should hinge up in the direction of the yellow battery pack.
  3. iRobot Roomba 4160 Brush Replacement: paso 3, imagen 1 de 2 iRobot Roomba 4160 Brush Replacement: paso 3, imagen 2 de 2
    • After the guard hinges up, lift the guard up and away from the Roomba.
  4. iRobot Roomba 4160 Brush Replacement, Brush: paso 4, imagen 1 de 1
    • Remove the wire brush by grabbing it by the yellow plastic part of the brush.
    • Pull the brush upwards until it comes out.
  5. iRobot Roomba 4160 Brush Replacement: paso 5, imagen 1 de 2 iRobot Roomba 4160 Brush Replacement: paso 5, imagen 2 de 2
    • Remove the rubber spinning brush by grabbing it by the rubber part on both ends.
    • Pull the brush upwards until it dislodges.
Conclusión
2 personas más completaron esta guía.
noah falck
Miembro Desde 04/07/14
104 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 6-4, Forte Spring 2014 Miembro de Cal Poly, Team 6-4, Forte Spring 2014
CPSU-FORTE-S14S6G4
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 297
