Saltar al contenido principal
iRobot Roomba 4160 Brush Guard Replacement
  1. iRobot Roomba 4160 Brush Guard Replacement, Brush Guard: paso 1, imagen 1 de 1
    • Make sure the Roomba is turned off to prevent injury.
    • Turn the Roomba upside down so that the underside is exposed. The wheels and brushes should be visible.
    • Identify the brush guard, which is the black rectangular frame that the metal rods are attached to.
  2. iRobot Roomba 4160 Brush Guard Replacement: paso 2, imagen 1 de 1
    • Locate the 2 small rectangular yellow tabs on either side of the brush guard, directly adjacent to the blue flap.
    • Place index fingers on both tabs, and apply slight pressure in the direction of the yellow battery pack.
    • While you are applying pressure, the guard should hinge up in the direction of the yellow battery pack.
  3. iRobot Roomba 4160 Brush Guard Replacement: paso 3, imagen 1 de 2 iRobot Roomba 4160 Brush Guard Replacement: paso 3, imagen 2 de 2
    • After the guard hinges up, lift the guard up and away from the Roomba.
Conclusión
Philippe Napaa
Miembro Desde 04/07/14
222 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 6-4, Forte Spring 2014 Miembro de Cal Poly, Team 6-4, Forte Spring 2014
CPSU-FORTE-S14S6G4
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 290
