Saltar al contenido principal
iRobot Roomba 4100 Brush Guard Replacement
  1. iRobot Roomba 4100 Brush Guard Replacement, Brush Guard: paso 1, imagen 1 de 1
    • Lay the Roomba upside down on a flat surface with the blue strip away from you.
  2. iRobot Roomba 4100 Brush Guard Replacement: paso 2, imagen 1 de 2 iRobot Roomba 4100 Brush Guard Replacement: paso 2, imagen 2 de 2
    • Use your index fingers to pull the yellow tabs towards you.
    • While still pulling the yellow tabs with your index fingers, tilt up the brush guard.
    • For reassembly, make sure to push in the brush guard until it clicks into place.
  3. iRobot Roomba 4100 Brush Guard Replacement: paso 3, imagen 1 de 1
    • Pull back the brush guard to unhook it from the latches.
    • Remove the brush guard by lifting it up and out of the Roomba.
    • This picture has a change in orientation to illustrate the latches. Continue disassembling the Roomba with the blue strip away from you.
Conclusión
Samantha Barrett
Miembro Desde 01/13/14
501 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 17-5, Forte Winter 2014 Miembro de Cal Poly, Team 17-5, Forte Winter 2014
CPSU-FORTE-W14S17G5
5 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 730
