Saltar al contenido principal
iRobot Roomba 4100 Battery Pack Replacement
Qué necesitas
  1. iRobot Roomba 4100 Battery Pack Replacement, Battery Pack: paso 1, imagen 1 de 1
    • Turn the Roomba upside down to be able to see the yellow battery pack.
  2. iRobot Roomba 4100 Battery Pack Replacement: paso 2, imagen 1 de 2 iRobot Roomba 4100 Battery Pack Replacement: paso 2, imagen 2 de 2
    • Remove the battery by placing your fingers into the two holes and firmly press your fingers against both sides of the battery.
    • Lift the battery directly up and out of the device.
  3. iRobot Roomba 4100 Battery Pack Replacement: paso 3, imagen 1 de 1
    • Line up the replacement battery’s larger tab side with the larger tab hole and the smaller tab side with the smaller tab hole.
    • Insert the replacement battery into the empty space and firmly press down onto the battery until two audible clicks are heard.
Conclusión
Your iRobot Roomba 4100 is now ready for use.
2 personas más completaron esta guía.
Equipo
Cal Poly, Team 20-6, Maness Fall 2010 Miembro de Cal Poly, Team 20-6, Maness Fall 2010
CPSU-MANESS-F10S20G6
2 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 17
Todo El Tiempo: 8,408
