Saltar al contenido principal
iRobot Looj 120 Controller Buttons Replacement
Qué necesitas
  1. iRobot Looj 120 Controller Buttons Replacement, Removing Screws: paso 1, imagen 1 de 1
    • Remove the four exterior screws located under controller and on the handle.
    • Remove the five screws shown, and then carefully remove top plate. Electrical components are attached to top plate.
  2. iRobot Looj 120 Controller Buttons Replacement, Locate Circuitry: paso 2, imagen 1 de 1
    • Disconnect circuit board from power leads, and install new circuit board.
  3. iRobot Looj 120 Controller Buttons Replacement, Remove Exterior Screws: paso 3, imagen 1 de 1
    • Remove the four exterior screws to gain access to inner components. These screws are located on the bottom of the controller and on the handle.
    • Remove the five interior screws to access the buttons.
  4. iRobot Looj 120 Controller Buttons Replacement, Accessing the Buttons: paso 4, imagen 1 de 1
    • Remove top plate carefully so that none of the electrical components are damaged.
    • Remove the broken button and insert the new button into the mounting hole.
Conclusión
Una persona más ha completado esta guía.
Lucas Otto
Miembro Desde 11/12/14
101 Reputación
1 Guía escrita
Equipo
UMass Dartmouth, Team 2-5, Duarte Fall 2014 Miembro de UMass Dartmouth, Team 2-5, Duarte Fall 2014
UMASSD-DUARTE-F14S2G5
3 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 10
Todo El Tiempo: 226
