Saltar al contenido principal
iRobot Braava 375t Cleaning Cloth Placement
  1. iRobot Braava 375t Cleaning Cloth Placement, iRobot Braava 375t Cleaning Cloth Placement: paso 1, imagen 1 de 2 iRobot Braava 375t Cleaning Cloth Placement, iRobot Braava 375t Cleaning Cloth Placement: paso 1, imagen 2 de 2
    • Flip your device upside down and locate the compartment for the cleaning cloth.
    • To remove the compartment, press down on the two buttons and lift upwards.
  2. iRobot Braava 375t Cleaning Cloth Placement: paso 2, imagen 1 de 1
    • Place your cleaning cloth onto a flat surface, with the textured side facing down. Then place the compartment on top of the cloth.
    • The compartment should line up with the middle section of the cloth.
  3. iRobot Braava 375t Cleaning Cloth Placement: paso 3, imagen 1 de 1
    • Once the compartment is lined up on the cloth, tuck the sides of the cloth into the jagged, blue rubber edges.
    • It is okay if there is overflowing on the outer corners. Just make sure the cloth is tucked in as much as possible in the middle and smooth out any creases or bunches.
  4. iRobot Braava 375t Cleaning Cloth Placement: paso 4, imagen 1 de 3 iRobot Braava 375t Cleaning Cloth Placement: paso 4, imagen 2 de 3 iRobot Braava 375t Cleaning Cloth Placement: paso 4, imagen 3 de 3
    • To put the compartment back line up the holes where the cloth peaks through to the two buttons on the underside of the device.
    • Once they are lined up then release the compartment and adjust if needed to make sure everything fits snuggly.
Conclusión
Una persona más ha completado esta guía.
Diego
Miembro Desde 09/26/22
235 Reputación
2 Guías creadas
Equipo
CSU Los Angeles, Team 5-5, Adachi Fall 2022 Miembro de CSU Los Angeles, Team 5-5, Adachi Fall 2022
CSULA-ADACHI-F22S5G5
6 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 89
