Saltar al contenido principal
iRobot Braava 320 Wheel Replacement
Qué necesitas
  1. iRobot Braava 320 Wheel Replacement, Battery: paso 1, imagen 1 de 1
    • Flip your device over and locate the battery cover.
    • The battery cover is located in the center of the device in between both wheels.
  2. iRobot Braava 320 Wheel Replacement: paso 2, imagen 1 de 1
    • Using a Flathead #4 screwdriver, gently turn the 12mm screw that holds the battery cover in.
    • The screw does not remove, it stays attached to the cover.
  3. iRobot Braava 320 Wheel Replacement: paso 3, imagen 1 de 2 iRobot Braava 320 Wheel Replacement: paso 3, imagen 2 de 2
    • Gently remove the battery from the tray and disconnect the battery cable.
    • To remove the battery, pull it straight up. To disconnect the cable, gently pull it straight out of the connector.
    • To reinstall the cable, hold it near the end and gently push it in the connector.
  4. iRobot Braava 320 Wheel Replacement, Body Shell and Control Panel: paso 4, imagen 1 de 1
    • With the battery removed, rotate your device so the front of it is facing you.
    • Remove the four 10mm Phillips #2 screws that attach the shell.
  5. iRobot Braava 320 Wheel Replacement: paso 5, imagen 1 de 2 iRobot Braava 320 Wheel Replacement: paso 5, imagen 2 de 2
    • Using both hands, hold the device together while you flip it over.
    • Starting from the front, gently lift up the shell and slowly tilt back until it is fully removed.
  6. iRobot Braava 320 Wheel Replacement, Wheel: paso 6, imagen 1 de 3 iRobot Braava 320 Wheel Replacement, Wheel: paso 6, imagen 2 de 3 iRobot Braava 320 Wheel Replacement, Wheel: paso 6, imagen 3 de 3
    • To remove the wheel covers, hold the wheel in place with one hand while turning the cover clock-wise with the other.
    • The cover should come off as soon as you hear a 'click' sound.
    • When replacing the cover, align the notches on the cover just to the right of the ones on the wheel.
  7. iRobot Braava 320 Wheel Replacement: paso 7, imagen 1 de 3 iRobot Braava 320 Wheel Replacement: paso 7, imagen 2 de 3 iRobot Braava 320 Wheel Replacement: paso 7, imagen 3 de 3
    • Using a small Flathead screwdriver, remove the small black clip in the center of the wheel.
    • To ensure the clip does not fly off, place your hand over the wheel to cover it as you remove the clip.
  8. iRobot Braava 320 Wheel Replacement: paso 8, imagen 1 de 3 iRobot Braava 320 Wheel Replacement: paso 8, imagen 2 de 3 iRobot Braava 320 Wheel Replacement: paso 8, imagen 3 de 3
    • Once the small black clip is removed, the wheel should come off by gently pulling on it.
    • Be careful not to lose the two small chrome pieces located on each side of the wheel.
Conclusión
13 personas más completaron esta guía.
Equipo
USF Tampa, Team S1-G3, Nance Spring 2017 Miembro de USF Tampa, Team S1-G3, Nance Spring 2017
USFT-NANCE-S17S1G3
4 Miembros
10 Guías creadas
Un comentario
O roteiro descritivo para a troca das rodas do Braava foi muito útil. Obrigada!
Vanilda Chueiri - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 60
Todo El Tiempo: 9,697
