Saltar al contenido principal
iRobot Braava 320 Deck Plate Assembly Replacement
Qué necesitas
  1. iRobot Braava 320 Deck Plate Assembly  Replacement, Battery: paso 1, imagen 1 de 1
    • Flip your device over and locate the battery cover.
    • The battery cover is located in the center of the device in between both wheels.
  2. iRobot Braava 320 Deck Plate Assembly  Replacement: paso 2, imagen 1 de 1
    • Using a Flathead #4 screwdriver, gently turn the 12mm screw that holds the battery cover in.
    • The screw does not remove, it stays attached to the cover.
  3. iRobot Braava 320 Deck Plate Assembly  Replacement: paso 3, imagen 1 de 2 iRobot Braava 320 Deck Plate Assembly  Replacement: paso 3, imagen 2 de 2
    • Gently remove the battery from the tray and disconnect the battery cable.
    • To remove the battery, pull it straight up. To disconnect the cable, gently pull it straight out of the connector.
    • To reinstall the cable, hold it near the end and gently push it in the connector.
  4. iRobot Braava 320 Deck Plate Assembly  Replacement, Body Shell and Control Panel: paso 4, imagen 1 de 1
    • With the battery removed, rotate your device so the front of it is facing you.
    • Remove the four 10mm Phillips #2 screws that attach the shell.
  5. iRobot Braava 320 Deck Plate Assembly  Replacement: paso 5, imagen 1 de 2 iRobot Braava 320 Deck Plate Assembly  Replacement: paso 5, imagen 2 de 2
    • Using both hands, hold the device together while you flip it over.
    • Starting from the front, gently lift up the shell and slowly tilt back until it is fully removed.
  6. iRobot Braava 320 Deck Plate Assembly  Replacement, Deck Plate Assembly: paso 6, imagen 1 de 1
    • With the shell off, flip the iRobot over and remove the four 10mm Phillips #0 screws holding the deck plate assembly on.
  7. iRobot Braava 320 Deck Plate Assembly  Replacement: paso 7, imagen 1 de 3 iRobot Braava 320 Deck Plate Assembly  Replacement: paso 7, imagen 2 de 3 iRobot Braava 320 Deck Plate Assembly  Replacement: paso 7, imagen 3 de 3
    • Remove the two 12mm Phillips #0 screws that hold the two springs onto the deck plate assembly.
    • Remove the two springs by gently lifting them up.
  8. iRobot Braava 320 Deck Plate Assembly  Replacement: paso 8, imagen 1 de 1
    • Flip the device over and remove the deck plate assembly cover by lifting it up.
  9. iRobot Braava 320 Deck Plate Assembly  Replacement: paso 9, imagen 1 de 1
    • Pull the arms together by lifting them up and to the center.
    • With the arms together. slide the deck plate up and over the arms until it is fully removed.
Conclusión
Equipo
USF Tampa, Team S1-G3, Nance Spring 2017 Miembro de USF Tampa, Team S1-G3, Nance Spring 2017
USFT-NANCE-S17S1G3
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 578
