Saltar al contenido principal
iRobot Braava 320 Body Shell Replacement
Qué necesitas
  1. iRobot Braava 320 Body Shell Replacement, Battery: paso 1, imagen 1 de 1
    • Flip your device over and locate the battery cover.
    • The battery cover is located in the center of the device in between both wheels.
  2. iRobot Braava 320 Body Shell Replacement: paso 2, imagen 1 de 1
    • Using a Flathead #4 screwdriver, gently turn the 12mm screw that holds the battery cover in.
    • The screw does not remove, it stays attached to the cover.
  3. iRobot Braava 320 Body Shell Replacement: paso 3, imagen 1 de 2 iRobot Braava 320 Body Shell Replacement: paso 3, imagen 2 de 2
    • Gently remove the battery from the tray and disconnect the battery cable.
    • To remove the battery, pull it straight up. To disconnect the cable, gently pull it straight out of the connector.
    • To reinstall the cable, hold it near the end and gently push it in the connector.
  4. iRobot Braava 320 Body Shell Replacement, Body Shell and Control Panel: paso 4, imagen 1 de 1
    • With the battery removed, rotate your device so the front of it is facing you.
    • Remove the four 10mm Phillips #2 screws that attach the shell.
  5. iRobot Braava 320 Body Shell Replacement: paso 5, imagen 1 de 2 iRobot Braava 320 Body Shell Replacement: paso 5, imagen 2 de 2
    • Using both hands, hold the device together while you flip it over.
    • Starting from the front, gently lift up the shell and slowly tilt back until it is fully removed.
Conclusión
Una persona más ha completado esta guía.
Adam Lewis
Miembro Desde 02/28/17
214 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S1-G3, Nance Spring 2017 Miembro de USF Tampa, Team S1-G3, Nance Spring 2017
USFT-NANCE-S17S1G3
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 706
