Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
iPod Touch 3rd Generation Power/Volume Controls Replacement
Qué necesitas
  1. iPod Touch 3rd Generation Power/Volume Controls Replacement, Front Panel: paso 1, imagen 1 de 1
    • The glass front panel on the third generation Touch has a plastic frame glued both to its outer edge and also under the wide black strips at the top and bottom of the device.
    • The picture at left (front panel already removed) shows the locations of the metal clips (shown in red) that snap on to the plastic frame. In the next few steps, try to pry the front panel up from the gaps between these clips.
    • Also, be mindful of the very thin and delicate touch screen ribbon cable (connector location shown in green) attaching the front panel to the upper left corner of the Touch.
    Pregunta a FixBot
  2. iPod Touch 3rd Generation Power/Volume Controls Replacement: paso 2, imagen 1 de 2 iPod Touch 3rd Generation Power/Volume Controls Replacement: paso 2, imagen 2 de 2
    • Gently insert an iPod opening tool between the glass front panel and its plastic surround near the volume adjust buttons.
    • Rotate the tool away from the Touch to pry up on the glass panel.
    • The key is to work slowly and gently to avoid breaking internal components.
    Pregunta a FixBot
  3. iPod Touch 3rd Generation Power/Volume Controls Replacement: paso 3, imagen 1 de 2 iPod Touch 3rd Generation Power/Volume Controls Replacement: paso 3, imagen 2 de 2
    • Insert the iPod opening tool between the front panel and its plastic surround and pry up at several points along the left edge of the Touch.
    • Do not insert the tool and run it down the edge of the front panel, as it will damage the front panel itself and the rubber strip along the plastic surround. It is best to work at one point, pry up, then remove the tool and reinsert it at the next spot to be pryed up.
    Pregunta a FixBot
  4. iPod Touch 3rd Generation Power/Volume Controls Replacement: paso 4, imagen 1 de 2 iPod Touch 3rd Generation Power/Volume Controls Replacement: paso 4, imagen 2 de 2
    • Continue prying up the left edge until the top and bottom edges start to lift out of the Touch.
    • Once the top and bottom edges have lifted slightly out of the Touch, use the opening tool to assure the plastic surround is detached from the clips along the inside of the Touch.
    Pregunta a FixBot
  5. iPod Touch 3rd Generation Power/Volume Controls Replacement: paso 5, imagen 1 de 1
    • Continue the prying procedure, now focusing on detaching the plastic surround from the internal metal clips.
    • Pry along the top edge of the Touch to further separate the front panel from the rest of the device.
    Pregunta a FixBot
  6. iPod Touch 3rd Generation Power/Volume Controls Replacement: paso 6, imagen 1 de 3 iPod Touch 3rd Generation Power/Volume Controls Replacement: paso 6, imagen 2 de 3 iPod Touch 3rd Generation Power/Volume Controls Replacement: paso 6, imagen 3 de 3
    • Pry up the front panel along the right edge using the method described in previous steps.
    • Eventually work around the entire perimeter of the front panel until it is lifted slightly from the rear panel.
    • Also, ensure that the plastic surround is separated from the clips in the rear panel.
    Pregunta a FixBot
  7. iPod Touch 3rd Generation Power/Volume Controls Replacement: paso 7, imagen 1 de 1
    • Lift the front panel out of the rear case minding the cable still attaching it near the upper left corner of the Touch.
    Pregunta a FixBot
  8. iPod Touch 3rd Generation Power/Volume Controls Replacement: paso 8, imagen 1 de 1
    • Use the flat end of a spudger (or an opening tool) to very carefully pry the touch screen cable connector up off the upper logic board.
    • The touch screen ribbon cable is extremely fragile! Be very gentle in disconnecting this cable to prevent tearing the ribbon cable.
    • Now that the front panel is out, check it for damage. If the plastic surround is not flush with the front face of the glass panel, gently peel it off and stick it down.
    • Be careful not to scratch the front panel on the underside of the black portions, as the scratches will be visible once the device is reassembled.
    • Be sure to clean both the face of the display and the inner surface of the front panel, as any dust or fingerprints will be trapped inside the Touch once it is fully reassembled.
    Pregunta a FixBot
  9. iPod Touch 3rd Generation Power/Volume Controls Replacement, Display: paso 9, imagen 1 de 1
    • Insert a small iPod opening tool with the edge angled up toward the underside of the display between the white plastic backlight and the metal shield beneath it.
    • Pry up along the lower edge of the display enough to grab it with your fingers, being careful to not flex the screen.
    Pregunta a FixBot
  10. iPod Touch 3rd Generation Power/Volume Controls Replacement: paso 10, imagen 1 de 1
    • Lift the display up from its lower edge and rotate it toward the top of the Touch.
    • The next few steps require removal of components under where the display normally sits. Be sure to hold the display to avoid putting tension on the delicate display ribbon cable.
    • Remove the seven Phillips screws securing the metal display tray to the rear panel. They may be very tight; watch carefully to make sure you don't strip them.
    • The two darker screws belong in the two holes in the tray nearest the bottom edge of the Touch.
    Pregunta a FixBot
  11. iPod Touch 3rd Generation Power/Volume Controls Replacement: paso 11, imagen 1 de 1
    • Lay the display back down into its tray.
    • Remove the final Phillips screw securing the metal tray to the rear panel.
    Pregunta a FixBot
  12. iPod Touch 3rd Generation Power/Volume Controls Replacement: paso 12, imagen 1 de 1
    • Lift the display out of the metal tray and rotate it toward the top edge of the Touch.
    • Use an iPod opening tool to lift the metal display tray and rotate it up toward the top edge of the Touch.
    Pregunta a FixBot
  13. iPod Touch 3rd Generation Power/Volume Controls Replacement: paso 13, imagen 1 de 1
    • Use the edge of an iPod opening tool to peel the copper tape off the top edge of the display.
    • Leave the copper tape attached to the metal display tray.
    Pregunta a FixBot
  14. iPod Touch 3rd Generation Power/Volume Controls Replacement: paso 14, imagen 1 de 1
    • Use the edge of an iPod opening tool to remove the piece of tape covering the display data cable.
    Pregunta a FixBot
  15. iPod Touch 3rd Generation Power/Volume Controls Replacement: paso 15, imagen 1 de 1
    • Use an iPod opening tool to pry the display data cable connector up off its socket on the logic board.
    Pregunta a FixBot
  16. iPod Touch 3rd Generation Power/Volume Controls Replacement: paso 16, imagen 1 de 1
    • Peel the display data cable off the adhesive securing it to the rear panel.
    Pregunta a FixBot
  17. iPod Touch 3rd Generation Power/Volume Controls Replacement: paso 17, imagen 1 de 1
    • Lift the metal display tray slightly (the battery is attached to its underside) and remove the display from the Touch, minding its delicate cable that may get caught.
    • The display ribbon cable is routed under the metal display tray.
    Pregunta a FixBot
  18. iPod Touch 3rd Generation Power/Volume Controls Replacement, Logic Board: paso 18, imagen 1 de 1
    • Use the flat end of a spudger to pry the battery off the adhesive securing it to the metal display tray.
    • Remove the metal display tray and set it aside.
    • Lay the battery flat in the rear panel.
    Pregunta a FixBot
  19. iPod Touch 3rd Generation Power/Volume Controls Replacement: paso 19, imagen 1 de 2 iPod Touch 3rd Generation Power/Volume Controls Replacement: paso 19, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Remove the single Phillips screw securing the gold pressure contact to the logic board.
    • Use a pair of tweezers to lift the Phillips screw out of the logic board.
    Pregunta a FixBot
  20. iPod Touch 3rd Generation Power/Volume Controls Replacement: paso 20, imagen 1 de 1
    • Remove the following three Phillips screws securing the logic board to the rear panel:
    • Two 2.3 mm screws
    • One 1.9 mm screw
    • The darker screw belongs in the screw hole next to the dock connector.
    Pregunta a FixBot
  21. iPod Touch 3rd Generation Power/Volume Controls Replacement: paso 21, imagen 1 de 2 iPod Touch 3rd Generation Power/Volume Controls Replacement: paso 21, imagen 2 de 2
    • Using the edge of an iPod opening tool, flip up the control button ribbon cable retaining flap.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • This socket is found under the battery.
    Pregunta a FixBot
  22. iPod Touch 3rd Generation Power/Volume Controls Replacement: paso 22, imagen 1 de 1
    • Carefully remove the two large pieces of tape securing the ribbon cables to the rear panel.
    Pregunta a FixBot
  23. iPod Touch 3rd Generation Power/Volume Controls Replacement: paso 23, imagen 1 de 1
    • Use the edge of an iPod opening tool to peel back the protective rubber grommet to reveal a hidden Phillips screw.
    • It is not necessary to completely remove this flap.
    • Remove the hidden Phillips screw.
    Pregunta a FixBot
  24. iPod Touch 3rd Generation Power/Volume Controls Replacement: paso 24, imagen 1 de 1
    • Remove the remaining Phillips screw securing the upper logic board to the rear panel.
    Pregunta a FixBot
  25. iPod Touch 3rd Generation Power/Volume Controls Replacement: paso 25, imagen 1 de 1
    • Carefully pull the lower logic board away from the lower edge of the rear panel.
    • Allow the edge of the logic board to rest on the outer edge of the rear panel.
    Pregunta a FixBot
  26. iPod Touch 3rd Generation Power/Volume Controls Replacement: paso 26, imagen 1 de 2 iPod Touch 3rd Generation Power/Volume Controls Replacement: paso 26, imagen 2 de 2
    • Use the edge of an iPod opening tool to carefully free the antenna connector cable from the adhesive securing it to the rear case.
    • Use the edge of your iPod opening tool to disconnect the antenna cable.
    Pregunta a FixBot
  27. iPod Touch 3rd Generation Power/Volume Controls Replacement: paso 27, imagen 1 de 1
    • Carefully peel the antenna cable off the adhesive securing it to the rear panel.
    Pregunta a FixBot
  28. iPod Touch 3rd Generation Power/Volume Controls Replacement: paso 28, imagen 1 de 1
    • Remove the small strip of tape securing the antenna socket ribbon cable to the rear panel.
    Pregunta a FixBot
  29. iPod Touch 3rd Generation Power/Volume Controls Replacement: paso 29, imagen 1 de 1
    • Use the edge of an iPod opening tool to peel the antenna socket ribbon cable off the rear panel.
    Pregunta a FixBot
  30. iPod Touch 3rd Generation Power/Volume Controls Replacement: paso 30, imagen 1 de 1
    • Use the edge of an iPod opening tool to carefully peel the Wi-Fi ribbon cable off the adhesive securing it to the rear panel.
    • Do not excessively strain the cable, as it tears easily.
    Pregunta a FixBot
  31. iPod Touch 3rd Generation Power/Volume Controls Replacement: paso 31, imagen 1 de 1
    • Use an iPod opening tool to pry the black plastic frame under the upper logic board up from the adhesive securing it to the rear panel.
    Pregunta a FixBot
  32. iPod Touch 3rd Generation Power/Volume Controls Replacement: paso 32, imagen 1 de 1
    • Carefully remove the logic board assembly from the rear panel, minding any cables that may get caught.
    Pregunta a FixBot
  33. iPod Touch 3rd Generation Power/Volume Controls Replacement, Power/Volume Controls: paso 33, imagen 1 de 1
    • Remove the two Phillips screws securing the power/volume controls to the rear panel.
    Pregunta a FixBot
  34. iPod Touch 3rd Generation Power/Volume Controls Replacement: paso 34, imagen 1 de 1
    • Use the tip of a spudger to remove the yellow kapton tape covering the power/volume control ribbon cable.
    Pregunta a FixBot
  35. iPod Touch 3rd Generation Power/Volume Controls Replacement: paso 35, imagen 1 de 1
    • Lift the power/volume controls out of the rear panel.
    Pregunta a FixBot
  36. iPod Touch 3rd Generation Power/Volume Controls Replacement, Power/Volume Controls: paso 36, imagen 1 de 1
    • Power/Volume controls remain.
    Pregunta a FixBot
Conclusión
16 personas más completaron esta guía.
1Guía Comentario
I would really recommend a brad new opening tool that has the edge in order to bite. I also had fairly good luck using the new iFlex.
Roger Clements - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 12
Ultimos 30 días: 101
Todo El Tiempo: 42,913
