Introducción
If your iPod Nano 7th Generation is no longer charging, it might be time to replace the battery. This guide will walk you through the steps to remove and replace the old battery with a new one, restoring your device to its former glory. The procedure involves disassembling the device, removing the old battery, and soldering a new one in place. Before you begin, ensure you have all the necessary tools and follow the instructions carefully to avoid damaging your iPod.
Qué necesitas
Lay the iOpener over the plastic tab to loosen the adhesive. Let the bag sit on the device for approximately 90 seconds before attempting to open the panel.
Use a cotton swab or Q-tip to remove any dust or lint on both sides of the iPod.
Using the iFixit opening pick, carefully pry open the device. Start from the edges and work your way around to separate the screen from the back cover.
Gently lift the screen to reveal the internal components.
Use the iFixit opening pick to disconnect the screen cable from the motherboard gently.
Una persona más ha completado esta guía.
