Saltar al contenido principal
Introducción
The plastic part on the top of the iPod.
  1. iPod Mini Top Bezel Replacement, Top Bezel: paso 1, imagen 1 de 1
    • Before opening your iPod, ensure that the hold switch is in the locked position.
    • Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic top. Use the screwdriver to pry up the white plastic top bezel. Be careful not to damage the soft plastic with your screwdriver.
    • The top bezel is held on with an adhesive, so it may be necessary to pry up in several different locations to free the part.
    • To make this job easier, heat up the adhesive with a hairdryer on low heat for a few seconds.
  2. iPod Mini Top Bezel Replacement: paso 3, imagen 1 de 1
    • Lift the top bezel off of the iPod.
Conclusión
12 personas más completaron esta guía.
iRobot
Miembro Desde 24/09/09
1 Reputación
646 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 58
Todo El Tiempo: 14,448
