Saltar al contenido principal
iPod 2nd Generation Hard Drive Replacement
Qué necesitas
  1. iPod 2nd Generation Hard Drive Replacement, Rear Panel: paso 1, imagen 1 de 1
    • Before opening your iPod, ensure that the hold switch is in the locked position.
  2. iPod 2nd Generation Hard Drive Replacement: paso 2, imagen 1 de 1
    • Opening the iPod can be challenging. Don't get discouraged if it takes a few tries before the iPod is opened.
    • Insert a plastic iPod opening tool in the seam between the white plastic front and metal back of the iPod. Once you've inserted the tool, run it along the seam to free the five tabs holding the iPod together.
  3. iPod 2nd Generation Hard Drive Replacement: paso 3, imagen 1 de 1
    • Continue to run the opening tool along the side of the case until all five tabs have been released.
  4. iPod 2nd Generation Hard Drive Replacement: paso 4, imagen 1 de 1
    • Work around the corner of the iPod and release the two tabs holding the iPod together near the dock connector.
  5. iPod 2nd Generation Hard Drive Replacement: paso 5, imagen 1 de 1
    • Free the five tabs holding the iPod together on the other side. You may be able to free the tabs by gently wiggling the front panel of the iPod.
  6. iPod 2nd Generation Hard Drive Replacement: paso 6, imagen 1 de 1
    • Lift the rear panel away from the iPod, making sure it doesn't catch on the headphone jack.
  7. iPod 2nd Generation Hard Drive Replacement, Hard Drive: paso 7, imagen 1 de 1
    • Peel up the metallic tape attached to the top of the battery.
  8. iPod 2nd Generation Hard Drive Replacement: paso 8, imagen 1 de 1
    • Lift the battery up from the hard drive and lay it next the the iPod (it is still connected to the logic board).
  9. iPod 2nd Generation Hard Drive Replacement: paso 9, imagen 1 de 1
    • Carefully disconnect the orange ribbon cable from the hard drive.
    • If the cable doesn't come free easily, it may be helpful to gently wiggle the cable from side to side.
    • Lift the hard drive out of the iPod.
Conclusión
Una persona más ha completado esta guía.
iRobot
Miembro Desde 09/24/09
1 Reputación
636 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 15
Ultimos 30 días: 64
Todo El Tiempo: 17,386
