Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
iPod 1st Generation Scroll Wheel Replacement
Qué necesitas
    1. iPod 1st Generation Scroll Wheel Replacement, Turn on the Hold switch: paso 1, imagen 1 de 1
      • Before beginning, be sure to activate the iPod's Hold switch to prevent the device from accidentally turning on.
      Pregunta a FixBot
      Agregar Comentario
    2. iPod 1st Generation Scroll Wheel Replacement, Cut a Strip of Tape: paso 2, imagen 1 de 1
      • Cut a strip of tape, preferably duct tape, about 6-8 inches long. Make sure it's wide enough to be able to cover the entire surface area of the Scroll Wheel
      • It is possible to use other types of tapes, like packing tape or stitched Scotch tape side-by-side, although it may take a few extra attempts in later steps.
      Pregunta a FixBot
      Agregar Comentario
    3. iPod 1st Generation Scroll Wheel Replacement, Prepping the iPod: paso 3, imagen 1 de 3 iPod 1st Generation Scroll Wheel Replacement, Prepping the iPod: paso 3, imagen 2 de 3 iPod 1st Generation Scroll Wheel Replacement, Prepping the iPod: paso 3, imagen 3 de 3
      • Lay the iPod flat on a solid table, then lay the strip of tape flat onto the Scroll Wheel, then press down on the entire surface of the Scroll Wheel & center Select button.
      Pregunta a FixBot
      Agregar Comentario
      • With one hand firmly grasping the iPod, pull the strip of tape upwards with your other to remove the Scroll Wheel from it's housing.
      • Be sure beforehand to slowly peel the tape off of the other buttons to prevent them from being pulled off as well, notably the Play/Pause button & the Menu button
      Pregunta a FixBot
      Agregar Comentario
    4. iPod 1st Generation Scroll Wheel Replacement, Remove Wheel parts from tape: paso 5, imagen 1 de 3 iPod 1st Generation Scroll Wheel Replacement, Remove Wheel parts from tape: paso 5, imagen 2 de 3 iPod 1st Generation Scroll Wheel Replacement, Remove Wheel parts from tape: paso 5, imagen 3 de 3
      • Simply peel off the Scroll Wheel & it's Select button from the strip of tape
      Pregunta a FixBot
      Agregar Comentario
    5. iPod 1st Generation Scroll Wheel Replacement, Done: paso 6, imagen 1 de 1
      • Congratulations! You've successfully removed the Scroll Wheel from your iPod 1st Gen.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
To reassemble your device, put the main Scroll Wheel mechanism back in first, followed by the center Select button.
edoogg
Miembro Desde 09/30/21
133 Reputación
1 Guía escrita
2Guía Comentarios
Very brutal and very effective.
Montary - Contestar Compartir
Made me laugh of how rudimental it is but how effective it is, is like making a depilation to the iPod
Foxy the dj - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 63
Todo El Tiempo: 1,161
