Saltar al contenido principal
iPod 1st Generation Battery Replacement
Qué necesitas
  1. iPod 1st Generation Battery Replacement, Rear Panel: paso 1, imagen 1 de 1
    • Before opening your iPod, ensure that the hold switch is in the locked position.
  2. iPod 1st Generation Battery Replacement: paso 2, imagen 1 de 1
    • Opening the iPod can be challenging; don't get discouraged if it takes you a few tries to get the iPod to open.
    • Insert a plastic iPod opening tool in the seam between the white plastic front and metal back of the iPod. It helps to hold the iPod at top and bottom as shown and squeeze to help pop out the edge. Once you've inserted the tool, run it along the seam to free the five tabs holding the iPod together.
  3. iPod 1st Generation Battery Replacement: paso 3, imagen 1 de 1
    • Continue to run the opening tool along the side of the case until all five tabs have been released.
  4. iPod 1st Generation Battery Replacement: paso 4, imagen 1 de 1
    • Work around the corner of the iPod and release the two tabs holding the iPod together near the dock connector.
  5. iPod 1st Generation Battery Replacement: paso 5, imagen 1 de 1
    • Free the five tabs holding the iPod together on the other side. You may be able to free the tabs by gently wiggling the front panel of the iPod.
    • Lift the rear panel away from the iPod.
  6. iPod 1st Generation Battery Replacement, Battery: paso 6, imagen 1 de 1
    • Lift the battery up from the adhesive holding it to the iPod.
    • Lay the battery next to the iPod (it is still connected to the logic board).
  7. iPod 1st Generation Battery Replacement: paso 7, imagen 1 de 1
    • Lift up the end of the hard drive near the Firewire port to allow easy access to the battery connector.
  8. iPod 1st Generation Battery Replacement: paso 8, imagen 1 de 1
    • Carefully disconnect the white battery connector from the logic board. Be sure to pull only on the connector itself and not on the cables.
Conclusión
32 personas más completaron esta guía.
iRobot
Miembro Desde 09/24/09
1 Reputación
636 Guías creadas
2 comentarios
There are so many iPods, it's confusing as to what battery to buy. I have 3 of these old bricks and sure it's battery time. Can you please provide a link to the specific battery for this (above) iPod?
caseyhales - Contestar
The iPod that I,m trying to resssurect has a connection that has 50t pin connection. I ordered the battery shown in the picture and now have to exchange it
drich92346 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 13
Ultimos 7 días: 62
Ultimos 30 días: 300
Todo El Tiempo: 42,402
