Saltar al contenido principal
iPhone XS Max Back Glass Replacement
Qué necesitas
Resumen del Video
  1. iPhone XS Max Back Glass Replacement, Back Glass Separating Without Phone Disassembling: paso 1, imagen 1 de 1
    • Here we have an iPhone XS Max with broken back glass. Run function test first. All going well. Test wireless charging - nothing goes wrong.
  2. iPhone XS Max Back Glass Replacement: paso 2, imagen 1 de 1
    • Next, let’s scan the back glass with the Laser Machine.
    • Turn the phone off and place it upside down under the focus positioning probe. Press the ‘auto focus’ button on the panel.
    • With the focus length indicator on, place the phone upside down on the operating panel.
  3. iPhone XS Max Back Glass Replacement: paso 3, imagen 1 de 1
    • Run the matching program. Choose corresponding model and drawing. Get all parameters set.
    • Click ‘Red Light’ to turn on laser aiming function. Click ‘Mark’ to scan the back glass with the laser light.
    • Note: there will be smog when the laser light is scanning. So we need to switch on the Air Purifier.
  4. iPhone XS Max Back Glass Replacement: paso 4, imagen 1 de 1
    • Once finished, the back glass becomes transparent.
    • Again, let’s turn on the phone and run function test. All going well. Wireless charging also goes well.
  5. iPhone XS Max Back Glass Replacement: paso 5, imagen 1 de 1
    • Next, let’s separate the back glass from the mid-frame. The scanned back glass can be separated easily.
    • Insert the metal pry piece into the gap between the back glass and the mid-frame. Slide back and forth to separate the back glass from the mid-frame.
  6. iPhone XS Max Back Glass Replacement: paso 6, imagen 1 de 1
    • Once the back glass has been separated completely, scan with the laser light to remove residual glue on the mid-frame.
  7. iPhone XS Max Back Glass Replacement: paso 7, imagen 1 de 1
    • Once done, clean the mid-frame thoroughly.
    • Apply some B7000 glue to the mid-frame. Get the new big hole back glass in position and adhere with proper force.
    • Once done, clip the four sides of the phone with clamps and wait several minutes for the glue to dry out.
Linea de Meta
16 personas más completaron esta guía.
Phryne
Miembro Desde 11/17/19
20,386 Reputación
18 Guías creadas
12 comentarios
Yeah, like I have a laser machine.
Gregg Stanley - Contestar
Thanks for the turorial. Like a laser machine can be found hanging around like a regular tool.
Franklin - Contestar
The actual !&&*? Is this a joke? TF is this doing here? Is that machine include with every iPhone?
Admer Bits - Contestar
This is the reason, why there is a note at the very top of this tutorial: This guide is meant for repair professionals.
There is a german saying: “Who can read has a huge benefit.” Just kidding … ;-)
BenZ78 - Contestar
i want to buy iphone xs max back panel (back glass)
SADAM TURK - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 26
Ultimos 7 días: 182
Ultimos 30 días: 747
Todo El Tiempo: 84,468
