Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
This is an advanced, professional-level repair for replacing only the glass portion on an iPhone XS cracked screen, also known as screen refurbishing.
Resumen del Video
  1. Test the display, touch functionality and 3D Touch of the screen. All going well.
    • Test the display, touch functionality and 3D Touch of the screen. All going well.
  2. Take apart the phone and remove the OLED Screen Assembly. Then put the OLED Screen Assembly on the Heating platform.
    • Take apart the phone and remove the OLED Screen Assembly. Then put the OLED Screen Assembly on the Heating platform.
    • Apply the specialized iPhone X/XS glue remover to the gap between the bezel and the OLED screen.
    • Cut out the top bracket with the Cutting Nipper and remove the ear speaker cover. Continue to separate the bezel with Pry Piece and Glue Remover. Then separate the bezel from the OLED with the Cutting Nipper.
  3. First, let’s stick adhesive tape on the broken glass lens. Then, place the OLED Screen Assembly on the Heat Platform.
    • First, let’s stick adhesive tape on the broken glass lens. Then, place the OLED Screen Assembly on the Heat Platform.
    • Remove residual glue on the ear speaker area with a blade.
    • Separate the glass lens from OLED with Cutting Wire.
  4. El kit de herramientas esencial
    Las herramientas más útiles en nuestro kit más compacto.
    Compra ahora
    Compra ahora
  5. OCA Glue removing can be finished with hand tearing.
    • OCA Glue removing can be finished with hand tearing.
  6. The OCA should be laminated to the glass lens at first.
    • The OCA should be laminated to the glass lens at first.
    • Then laminate the OCA attached glass lens to the OLED Screen.
    • This step is quite complicated and please check out the video for detailed operation.
  7. Put the OLED Screen Assembly into Bubble Removing Machine for 10 minutes.
    • Put the OLED Screen Assembly into Bubble Removing Machine for 10 minutes.
  8. Prepare a new piece of iPhone XS bezel. Apply the 460 glue to the bezel. Apply pressure to fit the OLED Screen Assembly with the bezel.
    • Prepare a new piece of iPhone XS bezel. Apply the 460 glue to the bezel. Apply pressure to fit the OLED Screen Assembly with the bezel.
  9. Get the OLED Screen Assembly installed and test. Run function test - Display; Touch; 3D Touch. All going well.
    • Get the OLED Screen Assembly installed and test. Run function test - Display; Touch; 3D Touch. All going well.
Phryne
Miembro Desde 17/11/19
14,796 Reputación
80 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 15
Ultimos 7 días: 166
Ultimos 30 días: 736
Todo El Tiempo: 4,592
