Saltar al contenido principal
iPhone XR Pentalobe Screws Replacement
Qué necesitas
  1. iPhone XR Pentalobe Screws Replacement, Remove the pentalobe screws: paso 1, imagen 1 de 2 iPhone XR Pentalobe Screws Replacement, Remove the pentalobe screws: paso 1, imagen 2 de 2
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
    • Opening the iPhone will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    • There's a black rubber gasket just beneath the head on each pentalobe screw. For maximum protection against dust and liquid, check the condition of the gaskets or replace the screws during reassembly.
Conclusión
10 personas más completaron esta guía.
Adam O'Camb
Miembro Desde 04/11/15
196,116 Reputación
416 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 56
Ultimos 30 días: 291
Todo El Tiempo: 19,717
