Saltar al contenido principal
iPhone 8 Speaker Replacement
Qué necesitas
  1. iPhone 8 Speaker Replacement, Speaker: paso 1, imagen 1 de 1
    • Sim card tray removal. This step is necessary as seen in Step 7.
    • Let the battery drain below 25% and power off the device before starting the repair.
  2. iPhone 8 Speaker Replacement: paso 2, imagen 1 de 2 iPhone 8 Speaker Replacement: paso 2, imagen 2 de 2
    • Remove the two bottom screws using the P2 bit in the Pro Tech Tool Kit.
  3. iPhone 8 Speaker Replacement: paso 3, imagen 1 de 3 iPhone 8 Speaker Replacement: paso 3, imagen 2 de 3 iPhone 8 Speaker Replacement: paso 3, imagen 3 de 3
    • Insert the Jimmy into the right side of the phone. Putting the Jimmy in the middle could crack the glass and/or break the home button. Also, don't put the Jimmy into the left side because you could break the home button cable. Use a small box to prop up the display as shown in picture 3.
  4. iPhone 8 Speaker Replacement: paso 4, imagen 1 de 3 iPhone 8 Speaker Replacement: paso 4, imagen 2 de 3 iPhone 8 Speaker Replacement: paso 4, imagen 3 de 3
    • Before we disconnect the display, we need to unplug the battery connector. If you don't unplug the battery first, you could damage the back light on the screen.
  5. iPhone 8 Speaker Replacement: paso 5, imagen 1 de 2 iPhone 8 Speaker Replacement: paso 5, imagen 2 de 2
    • Now to remove the display. There are 3 more screws that we need to remove, then we can disconnect the 3 cables.
    • Remove the display from the housing.
  6. iPhone 8 Speaker Replacement: paso 6, imagen 1 de 1
    • Now we need to remove this bracket. The screw next to the Taptic Engine is a Y000.
  7. iPhone 8 Speaker Replacement: paso 7, imagen 1 de 2 iPhone 8 Speaker Replacement: paso 7, imagen 2 de 2
    • Disconnect the marked flex cables, then push the sim pin ejector into the frame. Now remove the 3 screws holding the speaker in place. Lift the speaker up and remove it as shown in picture 2.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 19
Ultimos 30 días: 119
Todo El Tiempo: 569
