Saltar al contenido principal
iPhone 7 Plus Battery Replacement
Qué necesitas
Resumen del Video
  1. iPhone 7 Plus Battery Replacement, Pentalobe Screws: paso 1, imagen 1 de 1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm pentalobe screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 7 Plus Battery Replacement, Mark your opening picks: paso 2, imagen 1 de 3 iPhone 7 Plus Battery Replacement, Mark your opening picks: paso 2, imagen 2 de 3 iPhone 7 Plus Battery Replacement, Mark your opening picks: paso 2, imagen 3 de 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  3. iPhone 7 Plus Battery Replacement, Anti-Clamp instructions: paso 3, imagen 1 de 3 iPhone 7 Plus Battery Replacement, Anti-Clamp instructions: paso 3, imagen 2 de 3 iPhone 7 Plus Battery Replacement, Anti-Clamp instructions: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    Anti-Clamp
    $24.95
    Comprar
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  4. iPhone 7 Plus Battery Replacement: paso 4, imagen 1 de 3 iPhone 7 Plus Battery Replacement: paso 4, imagen 2 de 3 iPhone 7 Plus Battery Replacement: paso 4, imagen 3 de 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. iPhone 7 Plus Battery Replacement: paso 5, imagen 1 de 2 iPhone 7 Plus Battery Replacement: paso 5, imagen 2 de 2
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick into the gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  6. iPhone 7 Plus Battery Replacement, Heat the display: paso 6, imagen 1 de 1
    • The next three steps show how to separate the screen using a suction cup.
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the phone for about 90 seconds in order to soften up the adhesive underneath.
  7. iPhone 7 Plus Battery Replacement, Separate the display: paso 7, imagen 1 de 2 iPhone 7 Plus Battery Replacement, Separate the display: paso 7, imagen 2 de 2
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
  8. iPhone 7 Plus Battery Replacement: paso 8, imagen 1 de 3 iPhone 7 Plus Battery Replacement: paso 8, imagen 2 de 3 iPhone 7 Plus Battery Replacement: paso 8, imagen 3 de 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  9. iPhone 7 Plus Battery Replacement: paso 9, imagen 1 de 3 iPhone 7 Plus Battery Replacement: paso 9, imagen 2 de 3 iPhone 7 Plus Battery Replacement: paso 9, imagen 3 de 3
    • Slide the opening pick up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Stop near the top left corner of the display.
    • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
  10. iPhone 7 Plus Battery Replacement, Screen information: paso 10, imagen 1 de 1
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
  11. iPhone 7 Plus Battery Replacement: paso 11, imagen 1 de 3 iPhone 7 Plus Battery Replacement: paso 11, imagen 2 de 3 iPhone 7 Plus Battery Replacement: paso 11, imagen 3 de 3
    • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
  12. iPhone 7 Plus Battery Replacement: paso 12, imagen 1 de 2 iPhone 7 Plus Battery Replacement: paso 12, imagen 2 de 2
    • Gently pull up on the suction cup to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
    • Pull on the small nub on the suction cup to remove it from the front panel.
  13. iPhone 7 Plus Battery Replacement: paso 13, imagen 1 de 3 iPhone 7 Plus Battery Replacement: paso 13, imagen 2 de 3 iPhone 7 Plus Battery Replacement: paso 13, imagen 3 de 3
    • Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive.
  14. iPhone 7 Plus Battery Replacement: paso 14, imagen 1 de 2 iPhone 7 Plus Battery Replacement: paso 14, imagen 2 de 2
    • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
  15. iPhone 7 Plus Battery Replacement: paso 15, imagen 1 de 3 iPhone 7 Plus Battery Replacement: paso 15, imagen 2 de 3 iPhone 7 Plus Battery Replacement: paso 15, imagen 3 de 3
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
  16. iPhone 7 Plus Battery Replacement, Battery Disconnection: paso 16, imagen 1 de 1
    • Remove the following four tri-point Y000 screws securing the lower display cable bracket to the logic board:
    • Three 1.2 mm screws
    • One 2.6 mm screw
  17. iPhone 7 Plus Battery Replacement: paso 17, imagen 1 de 2 iPhone 7 Plus Battery Replacement: paso 17, imagen 2 de 2
    • Remove the lower display cable bracket.
  18. iPhone 7 Plus Battery Replacement: paso 18, imagen 1 de 3 iPhone 7 Plus Battery Replacement: paso 18, imagen 2 de 3 iPhone 7 Plus Battery Replacement: paso 18, imagen 3 de 3
    • Use the point of a spudger to lift the battery connector out of its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to the phone.
  19. iPhone 7 Plus Battery Replacement, Display Assembly: paso 19, imagen 1 de 3 iPhone 7 Plus Battery Replacement, Display Assembly: paso 19, imagen 2 de 3 iPhone 7 Plus Battery Replacement, Display Assembly: paso 19, imagen 3 de 3
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use the flat end of a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
    • To re-attach press connectors, press down on one end until it clicks into place, then repeat on the other end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
  20. iPhone 7 Plus Battery Replacement: paso 20, imagen 1 de 3 iPhone 7 Plus Battery Replacement: paso 20, imagen 2 de 3 iPhone 7 Plus Battery Replacement: paso 20, imagen 3 de 3
    • Remove the three tri-point Y000 screws securing the bracket over the front panel sensor assembly connector:
    • One 1.3 mm screw
    • Two 1.0 mm screws
    • Remove the bracket.
  21. iPhone 7 Plus Battery Replacement: paso 21, imagen 1 de 2 iPhone 7 Plus Battery Replacement: paso 21, imagen 2 de 2
    • Disconnect the front panel sensor assembly connector from its socket on the logic board.
    • This press connector should also be reconnected one end at a time to minimize the risk of bending.
  22. iPhone 7 Plus Battery Replacement: paso 22, imagen 1 de 1
  23. iPhone 7 Plus Battery Replacement, Barometric Vent: paso 23, imagen 1 de 1
    • Remove the following two Phillips screws securing the barometric vent to the rear case:
    • One 2.9 mm screw
    • One 2.1 mm screw
  24. iPhone 7 Plus Battery Replacement: paso 24, imagen 1 de 2 iPhone 7 Plus Battery Replacement: paso 24, imagen 2 de 2
    • Gently push the barometric vent in the direction of the Taptic Engine to separate the adhesive securing it to the bottom edge of the iPhone.
  25. iPhone 7 Plus Battery Replacement: paso 25, imagen 1 de 1
    • Remove the vent.
  26. iPhone 7 Plus Battery Replacement, Taptic Engine: paso 26, imagen 1 de 2 iPhone 7 Plus Battery Replacement, Taptic Engine: paso 26, imagen 2 de 2
    • Use the flat end of a spudger to disconnect the Taptic Engine connector from its socket on the logic board.
  27. iPhone 7 Plus Battery Replacement: paso 27, imagen 1 de 1
    • Remove the three 1.5 mm Phillips screws securing the Taptic Engine to the rear case.
  28. iPhone 7 Plus Battery Replacement: paso 28, imagen 1 de 2 iPhone 7 Plus Battery Replacement: paso 28, imagen 2 de 2
    • Remove the Taptic Engine.
  29. iPhone 7 Plus Battery Replacement, Battery: paso 29, imagen 1 de 3 iPhone 7 Plus Battery Replacement, Battery: paso 29, imagen 2 de 3 iPhone 7 Plus Battery Replacement, Battery: paso 29, imagen 3 de 3
    • Peel back the three adhesive strips on the lower edge of the battery.
    • If possible, use your fingernails or blunt tweezers. Be careful not to poke the battery with any sharp tools.
  30. iPhone 7 Plus Battery Replacement: paso 30, imagen 1 de 3 iPhone 7 Plus Battery Replacement: paso 30, imagen 2 de 3 iPhone 7 Plus Battery Replacement: paso 30, imagen 3 de 3
    • Try to keep the strips flat and unwrinkled during this procedure; wrinkled strips will stick together and break instead of pulling out cleanly.
    • Slowly pull one battery adhesive tab away from the battery, toward the bottom of the iPhone.
    • Pull steadily, maintaining constant tension on the strip until it slips out from between the battery and the rear case. For best results, pull the strip at a 60º angle or less.
    • The strip will stretch to many times its original length. Continue pulling and re-grab the strip near the battery if necessary.
  31. iPhone 7 Plus Battery Replacement: paso 31, imagen 1 de 2 iPhone 7 Plus Battery Replacement: paso 31, imagen 2 de 2
    • Repeat the previous step for the second and third strips.
    • Hold down the battery as you remove the final strip, or the strip may fling the battery when it separates from the case.
    • If you removed all adhesive strips successfully, skip the next step.
    • Otherwise, if any of the adhesive strips broke off underneath the battery and could not be retrieved, continue with the next step below.
  32. iPhone 7 Plus Battery Replacement: paso 32, imagen 1 de 3 iPhone 7 Plus Battery Replacement: paso 32, imagen 2 de 3 iPhone 7 Plus Battery Replacement: paso 32, imagen 3 de 3
    • If any of the adhesive strips broke off and the battery remains stuck to the rear case, remove it by adding a few drops of isopropyl alcohol (90% or greater) underneath the battery near the stuck strip(s).
    • After about a minute, gently lift the battery.
    • Do not insert your spudger in the area between the volume down (-) button and the top edge of the battery, or you may damage the volume control cable lying underneath.
    • Do not pry against the logic board or you may damage the phone.
    • Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
    • If the battery remains stuck to the rear case, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery. It should be slightly too warm to touch comfortably.
    • Overheating the iPhone may ignite the battery.
    • A piece of dental floss may be used to separate the battery from the rear case. A stronger alternative to dental floss is an unwound guitar string, such as a 0.009 E string from a 12-string set. Thread the floss or string behind the upper battery corners, bring the ends together, wrap them around a folded cloth, and pull evenly.
  33. iPhone 7 Plus Battery Replacement: paso 33, imagen 1 de 1
    • Remove the battery.
    • If your replacement battery came in a plastic sleeve, remove the sleeve before installation by pulling it away from the ribbon cable.
    • If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
    • Before you adhere the replacement battery, temporarily reconnect the battery connector to the logic board socket. This ensures that the battery is properly aligned in its recess.
    • Adhere the battery, disconnect it, and continue reassembling your device.
    • If your new battery doesn’t have adhesive preinstalled, refer to this guide to replace the adhesive strips.
    • Perform a force restart after reassembly. This can prevent several issues and simplify troubleshooting.
Conclusión
Repair didn’t go as planned? Try some basic troubleshooting, or search our Answers forum for help.
406 personas más completaron esta guía.
Scott Havard
Miembro Desde 06/27/16
49,621 Reputación
31 Guías creadas
51 comentarios
can the battery from iPhone 7plus fit in the 6s plus? looks to me like is the same type of connector and same dimensions so it would be an easy way to gain 150 extra mah by using the iphone 7 plus battery
Alex
alexandrupaulpopa - Contestar
No, because the size are diferents
JOSE RAMON -
Of course you can! WHY NOT?
Manuel Tugentman - Contestar
How can I attach the screen back to the body after replacing the old battery,do i need any adhesive to attach the screen to the body?
Kaustubh Iyer - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 112
Ultimos 7 días: 778
Ultimos 30 días: 2,709
Todo El Tiempo: 472,933
