Saltar al contenido principal
iPhone 7 Logic Board Disconnection
Sólo Prerrequisito
Esta guía solo debería usarse como prerrequisito para otras guías. Por tanto, estará incompleta.
Qué necesitas
  1. iPhone 7 Logic Board  Disconnection, Logic Board Connectors: paso 1, imagen 1 de 2 iPhone 7 Logic Board  Disconnection, Logic Board Connectors: paso 1, imagen 2 de 2
    • Use the flat end of a spudger to disconnect the rear-facing camera connector.
  2. iPhone 7 Logic Board  Disconnection: paso 2, imagen 1 de 2 iPhone 7 Logic Board  Disconnection: paso 2, imagen 2 de 2
    • Remove the following Phillips screws securing the rear camera bracket to the rear case:
    • One 1.3 mm screw
    • One 2.5 mm screw
  3. iPhone 7 Logic Board  Disconnection: paso 3, imagen 1 de 1
    • Remove the bracket.
  4. iPhone 7 Logic Board  Disconnection: paso 4, imagen 1 de 2 iPhone 7 Logic Board  Disconnection: paso 4, imagen 2 de 2
    • Use the pointed end of a spudger to pry up and disconnect the antenna bus connector, just left of the rear camera module.
  5. iPhone 7 Logic Board  Disconnection: paso 5, imagen 1 de 1
    • Remove the two 1.2 mm tri-point screws securing the upper cable bracket.
  6. iPhone 7 Logic Board  Disconnection: paso 6, imagen 1 de 2 iPhone 7 Logic Board  Disconnection: paso 6, imagen 2 de 2
    • Remove the upper cable bracket.
  7. iPhone 7 Logic Board  Disconnection: paso 7, imagen 1 de 2 iPhone 7 Logic Board  Disconnection: paso 7, imagen 2 de 2
    • Use the flat end of a spudger to disconnect the upper cable connector.
  8. iPhone 7 Logic Board  Disconnection: paso 8, imagen 1 de 2 iPhone 7 Logic Board  Disconnection: paso 8, imagen 2 de 2
    • Remove the four Phillips screws securing the Wi-Fi antenna:
    • Three 1.2 mm screws
    • One 1.7 mm screw
  9. iPhone 7 Logic Board  Disconnection: paso 9, imagen 1 de 2 iPhone 7 Logic Board  Disconnection: paso 9, imagen 2 de 2
    • Remove the top left antenna.
  10. iPhone 7 Logic Board  Disconnection: paso 10, imagen 1 de 1
    • Remove the following Phillips screws:
    • One 1.3 mm screw
    • One 2.2 mm screw
  11. iPhone 7 Logic Board  Disconnection: paso 11, imagen 1 de 2 iPhone 7 Logic Board  Disconnection: paso 11, imagen 2 de 2
  12. iPhone 7 Logic Board  Disconnection: paso 12, imagen 1 de 1
    Herramienta utilizada en este paso:
    Standoff Screwdriver for iPhones
    $5.49
    Comprar
    • Remove the 2.2 mm standoff screw from the grounding bracket.
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
  13. iPhone 7 Logic Board  Disconnection: paso 13, imagen 1 de 2 iPhone 7 Logic Board  Disconnection: paso 13, imagen 2 de 2
    • Use tweezers to gently bend the logic board grounding bracket out of the way.
Conclusión
Evan Noronha
Miembro Desde 02/05/15
223,466 Reputación
168 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 184
